Question about Toshiba Satelite 5205-S505 Notebook
Upgrade my graphics
I would like to upgrade my graphics card on my toshiba satelite 5205 s505. It has a nvidia geo force 460 in it now. I wouldl like to play better games.
    Genius:
  • 1,605 Answers
Be warned: If the upgrade is possible at all for your laptop, it can be a time-consuming operation that involves disassembling virtually your entire notebook, so don't enter into this process unless you are willing to accept the risk of doing serious harm to your machine.
On some newer, high-end notebooks, the graphics card can be accessed simply by opening a panel on the bottom of the computer. But for most older machines, disassembly will take more steps.
The first thing you need to know is that your laptop can probably support only a handful of very specific graphics cards, if the card can be upgraded at all. Your best source for an upgrade card will likely be the manufacturer that made your portable.
Be sure to consult your laptop's service manual (which can usually be downloaded from the manufacturer's support page) before attempting to open up your machine. Also, make sure you guard your hardware against possible electrostatic discharge by wearing an antistatic wrist strap whenever you handle any internal components.
If you really want to upgrade your graphic card, let me know and post the additonal question in the thread. I will try to answer your questions.
Posted on Nov 24, 2008
Can i use any charger on s505
The Toshiba Satellite 5205 series of Notebook PC, and the S505 series model; uses an AC adapter (Charger) that produces 15 Volts DC.
http://www.sparepartswarehouse.com/Toshiba,Satellite,5205,PS520U-31P1RV,Laptop,AC-Adapters.aspx
You will see AC adapters sold that show 15 to 24 Volts. (DC)
http://www.duracelldirect.com/toshiba_satellite-5205-s505_ac-adapters_laptop_ac-b20h.aspx
This is because the AC adapter (Charger) has PFC.
Power Factor Correction,
http://www.hardwaresecrets.com/article/Everything-You-Need-to-Know-About-Power-Supplies/181/2
Also I see it is just a two pin AC adapter plug, to laptop.
Center hole is Positive, outer metal cylindrical metal shell is Negative.
Go for 75 Watts or higher though, and not a 65 Watt model.
[ On the case of the AC adapter;
Input: 100 ~ 240 VAC 50-60Hz
Means it can use from 100 to 240 Volts AC, and either 50 or 60 Hertz.
Output: 15VDC 6A
Means 15 Volts DC at 6 Amp's. (Amperes)
Watch the outside dimension of the cylindrical part, and the center hole dimension. Outside cylinder may be correct, but center hole may be too small. Or vice-versa.
Regards,
joecoolvette
Dec 17, 2012 | Toshiba Satelite 5205-S505 Notebook
Toshiba Satelite Asos screen is blank after logon
This indicates a hard drive problem, but! first remove the hard drive and re-seat it back in place, "sometimes it goes out of position" and is enough to restart it, if no change! use your recovery disc to reload windows. Now! if it fails to load up chances are it is probably a bad hard drive, but I recommend having it tested before replacement of the hardware.
Apr 01, 2011 | Toshiba Satelite 5205-S505 Notebook
My toshiba laptop powers on but doesn't boot up to windows until after i open and close my dvd drive
if there is a quick release for the drive - pop it out entirely and see if works then. You are looking at replacing the drive or motherboard.
Feb 25, 2011 | Toshiba Satelite 5205-S505 Notebook
Sometimes my toshiba p100-347 will not boot for several attempts, and then just out the blue it powers up fine, any clues?, i took it to a computer repair shop and they diagnosed a faulty graphics card...
all booting is done from the hard drive and not the graphics card
if you have the monitor running directly from the mother board connections and there is a problem it could be a mother board
if you have the monitor from the graphic card connections then it could be a graphic or in both instances a problem monitor
graphic cards are around the 40 pound ($60.00aud mark so what you have been quoted is way over the top for a card
the problem may be a failing hard drive so make sure that all files , folders and data is saved on an external hard drive
Jun 06, 2017 | Toshiba Satelite 5205-S505 Notebook
I have a toshiba satelite and it keeps freezing every 10 minutes
Sounds like the Processor fan is not working.When you turn the unit on , llisten for the fan . If it is not spinning, it is bad. The reason it shuts down is to protect your unit from further damage. Let me know what model, and I will see if I have the service manual or the instructions on how to replace the fan.
Nov 20, 2009 | Toshiba Satelite 5205-S505 Notebook
CPU upgrade for Satellite 5205-S505
You would only get a marginal performance increase. If your laptop has 256Mb of RAM, increasing the RAM up to 1Gb (this model laptop cannot support more than 1Gb RAM) would boost the performance of the laptop.
Jun 20, 2009 | Toshiba Satelite 5205-S505 Notebook
As soon as I turn on the laptope and it clears it freezes
Try starting in safe mode (tap F8 just after Toshiba logo) and see if you can correct a hardware address conflict.
Mar 14, 2009 | Toshiba Satelite 5205-S505 Notebook
How do I go Wireless with my Toshiba 5205-S505 Laptop?
for getting wireless u need the following: a wireless access point or a router..access points are easy to configure..good ones are from linksys(other brands are Netgear,D link,Belkin etc) Linksys WAP54G Wireless-G Access Point..and your pc/laptop needs to be wifi enabled..if they are not you can get a USB adapter again from Linksys..just follow the instructions and you are good to go!do secure your wifi network once you make it..hope it helps!
shall be glad to help further..
Nov 19, 2008 | Toshiba Satelite 5205-S505 Notebook
How can I install my recovery CD's if my DVD/CD drive doesn't work
I had a similar problem with an IBM thinkpad once. My solution was to purchase a PCMCIA CDROM drive and boot from that. Go to: http://froogle.google.com/frghp?ie=UTF-8&oe=UTF-8&hl=en&tab=wf&q= and search for "PCMCIA CDROM". Your laptop should boot from one of these devices.
Feb 14, 2007 | Toshiba Satelite 5205-S505 Notebook
Toshiba Satelite 5205-S505 Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
