Brandt coin counting machine does not come on when plugged in. Digital display won't light up, machine doesn't come on.
  • 343 Answers
All Brandt machine have a fuse in the back. See if its blown. Replace it. Doesn't fix? you have a bad display board. Replace that.
Posted on Dec 21, 2009
I might ca help if you have a model number.vlappe@aol.com
Posted on Feb 24, 2009
I have a Brandt 1200 series coin counter that won't turn on. The display works, just won't start. Does anyone have a service manual or solution to the problem?
I work for the former Brandt company, now called Glory.
Let me be clear on this. The Brandt/Glory company makes the best counters on the planet. That being said the model 1200 is the worst design ever. I never liked it and it's been last made 25 years ago.
Lets start simple. In the back of the machine there are 2 fuses. F1 protects the motor and is a 3 amp fuse. F2 is a 1/2 amp fuse to protect the display. Make sure they are good.
Next you'll have to take the back off to see if the belt is broke or the pulley fell off. Or, the motor plug has come loose?
Do a machine reset by unpluging the power cord. Then while pressing and holding the "C" key, plug the machine back in and wait 5 seconds. If the above does not help at all, you have more serious problems like bad motor, bad motor controller.
You can try calling me at nine8five 8ninethree 5two4one
Good luck
Jun 10, 2015 | Retail Supplies
Hi there Washing Machine model: WFA0877A My wash cycle was abruptly ended and all three indicator lights are switched on. How do I resolve this?
http://www.manualsdrive.com/results.php?lang=en&search=BRANDT%20WFA0877A#.VIhIUXtwnBQ
send your email get the user manual
all three lights on is blocked up drain
the pump not rotating {check for wires and coins}
i would empty the machine fully at the drain cycle and also at the pump filter
till its all empty
switch off and remove the water pipes and the mains plug
then pull out and lay the machine over on the side
opposite the soap drawer
then underneath you will see the pipe that goes from the drum
to the pump
take it off both ends and check its totally clear and any trap {a ball and also sometimes in a cage}
shine a light inside the drums and look around for socks or tights or plastic etc {have kids check for lego plastic toys etc etc }
clothing wires in the pump end
and check the drain
make sure the drain at the waste end is clean and flows well at the sink etc...
put it all back together
and try to hold in the program select or start stop button for a few seconds when you apply mains
then this resets the fault it detected
it should work aok
if not what part of the cycle did or does it stop at???
this will give more info that the three stuck lights
i can see the manual online for it
perhaps it has some details
Dec 10, 2014 | Brandt Washing Machines
How to save setting on brandt 8672
The 8672 is a terrific machine. Once you change any setting it will automatically save it as the new default setting when powered up.
Oct 12, 2014 | Brandt 8672 Note Counter
Brandt coin counter and sorter, looking for a manual for it, not sure of model, have a pic of it
No one can give you a manual with out a model number! There are hundreds of models. A picture would be helpful.
Call me, I may have one if I can "see" the machine.
Harry 985 / 893-52four one
Nov 11, 2013 | Retail Supplies
What is the maximum amount of bills a bill counter can count?
From what I have read, it seems that what matters the most is the speed of the counter. In this article I found, the fastest counter can count 1500 bills per minute:
http://www.abcoffice.com/office-equipment-news/tag/bill-counter-reviews/
Apr 29, 2013 | Retail Supplies
Hi - I have won a Brandt digital photo frame and radio in a raffle but unfortuantley, it has no instructions - can you help ?
Sorry- not from the WASHING MACHINE forum ;-0(
You will need to type into your search engine/web browser 'brandt digital photo frame' and you MAY be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Aug 15, 2011 | Brandt Washing Machines
The LED for my Brandt 1200 series coin counter is
Are you saying the display is blank?
Try this: While holding down the "Clear" button, plug the machine into the wall outlet. This is called a power up clear. Sometimes this solves corrupt date and tries to reset itself.
If that doesn't work, here is the number to call for help. 800 527-2636 Have your serial number handy. If you wish, a service man could be dispatched to help you. By the way, that machine has not been made for at least 12 years. Hope this helps. Good luck
Jan 15, 2010 | Office Equipment & Supplies
701 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
