Question about Toshiba 50H82 50" Rear Projection Television
No picture or sound
I have a Toshiba model 50H82. I just lost the picture AND the sound. It was working fine, I turned it off one night, when I wanted to turn it back on the next night, there was no picture OR sound. The red LDE comes on and that is all. I live 90 miles our in the sticks and would like to be able to fix this myself as a service call just to pick up the tv is 250 $ ! I have a great background in electronics and have been a ham radio operator for 40 years. I think i could fix it IF I knew what to replace. THANK YOU for your time and help with my problem Ernie If you have the answer you may e-mail me direct at leewalt@powerbank.net
  • gloria23 Dec 02, 2007
    last night I lost my audio in my Toshiba 42" HD TV abruptly. Never happened before-
    Scholar:
  • 168 Answers
This symptons is usually caused by a breakdown in the power supply. it may also be caused by a breakdown in the horizontal deflection circuits(hor. oscillator, pre drive or drive ckts.). this because the supplu voltages from tuner, video intermediate frequency (vif), video amplifier, sound intermediate frequency(sif), and vertical output are usually supplied by horizontal output circuit. switch on the receiver and check whether the pilot lamp is on, or the filament of the crt is glowing. if not, possible short circuit before the rectifier circuit such as fuse, power cord or switch. if the pilot lamp is on or the filament of the crt is glowing, check the b+ supply voltage for the horizontal deflection circuit. if the b+ voltage is zero or very low, check the rectifier circuit and the voltage regulator circuits. if b+ is nrmal, troubleshoot the horizontal deflection circuits.
Posted on Jan 16, 2007
SOURCE:
Toshiba Model 57H83 Rear Projection TV Lost Picture and Sound
the most common problem in this set is convergence---two chips are used and if one shorts what you have happens--only way to prove this is get at and unsolder all 18 pins on both chips----if set turns on then the chips and or a resistor near them are bad.
Soldering and getting at the chips requires some skill--the parts involved usually are under 30 dollars total.
set uses chips like these:
Nov 04, 2012 | Televison & Video
The picture on our Toshiba 50H82 rear projection tv is shaky, any diy solutions for this?The picture will sometimes clear up after about 30 minutes. Can this be fixed? The sound is fine, it's just the...
Thats almost always caused by the surface mount capacitors which get weak on the hyper board. Hyper boards are going to be hard to find. But the capacitors can be replaced which will usually solve the issue. However it will require precise soldering skills to do the repair.
Oct 06, 2011 | Toshiba 50H82 50" Rear Projection...
Av and cable inputs stopped working over night
this is caused by your Hyper board failing
It is not availble anymore but try Tops Electronics in Haverhill ma or shop jimmy.com
Nov 24, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba Model No. 50A62 When the set is first turned on, the screen is black with white snow and no sound. After 5 minutes, we get a normal picture. I get the same results, everytime it is turned off and...
It sound to me like your tuner is going out. I would suggest that you contact a local service center to get the tuner replaced or just put up with it as long as you can.
I hope this helps.
Thanks
asnowman
Sep 21, 2009 | Toshiba 50H82 50" Rear Projection...
No picture, no sound, but has power light...any suggestions? thx in advance
Do this first:
1: Check the antenna/cable connections.
2: Press the TV/VIDEO on the remote control or the TV to view a signal coming from another device connected to your TV, such as a VCR or
video disc player. You can select ANT 1,
VIDEO 1, VIDEO 2, VIDEO 3, ColorStream HD1, ColorStream HD2, or ANT 2 depending on which input jacks are used for connecting the devices.
*Be sure you have the right source to view video.
Try the above and post back before I can say there is a problem with your unit. If you have the user manual it's a good time to get it out. If you don't have it let me know and I will give you a link to obtain it. Good luck!!
May 23, 2009 | Toshiba 50H82 50" Rear Projection...
Picture problem on 50H82
the hyper module needs replacement or repair.
there are many dried surface mount caps on the board and they are dried out. best let a tech do the job
Jun 17, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 blue arcing?
color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Dec 18, 2007 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 blown fuse f470
Solder jumper wires for prevent maintenance.....on signal
board = 008,010,017,048,600.............................T.
Oct 23, 2007 | Toshiba 50H82 50" Rear Projection...
No pic no sound
sounds like convergence drive ics or power supply.would be about $350.00 +++ for these type of repairs
Sep 07, 2007 | Toshiba 42H82 42" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
158 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
