Question about GE 25881EE3 Phone
GE Phone Model 25881
It is a multi handset phone with the base being a corded phone. There are two cordless handsets with the phone. The phone service is in pulse, but the phone is on tone. How can it be changed on this model?
  • Blunder Dec 29, 2007
    I can't find any mechanical switch or progammable option to switch from tone to pulse.
    Scholar:
  • 135 Answers
Per the instruction manual, there is supposed to be a switch on the base (look on the back or bottom) for TONE/PULSE mode. Here is a link to the manual: http://www.home-electronics.net/GE/ProductDownloads/25881EE3_IB.pdf In the "troubleshooting" section, there is this entry: Dial tone is OK, but can?t dial out: Make sure the TONE/PULSE setting on the base is set to the type of phone service you are subscribed to.
Posted on Mar 04, 2007
My corded phone works ok, but on the hand set I can make calls but people can not hear me.
Posted on Jul 28, 2008
I have a GE cord and cordless speaker model: 26955-GE 900mhz phone which i have had for eight year and I would like to add another cordless phone which GE phone is compatible to what I'm currently using....
If you mean you'd like to add another handset to the base unit on this phone, I'm afraid you can't. This isn't a multi-handset phone and isn't expandable. If you want the kind of system that has the main base unit and several separate handsets, you'll have to start fresh with a new system. They aren't expensive.
Mar 09, 2010 | GEH5450 Cordless Phone
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
2nd request: Model 27956 GE Cordless Handset with Picture Caller ID & Slide Show. Won't work after power outage. White & gray screen only. Disconnected and reconnected as advised by service call....
This fixed mine:
1/15/10
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
Sep 02, 2009 | Uniden Cordless Phone
Hand set out of range disply is on. How do I reset.
here are some tips from my manual for out of range problems
hope they help
• Only one handset can be used to make or answer a call anytime.
If another handset attempt to do so, the screen will display OTHER
HANDSET ON and then OR OUT OF RANGE. You might press PHONE
or SPEAKER again until no other handset is using the line. Use the call
transfer feature to transfer a call to another system handset
or use the speakerphone feature so multiple members of your
house can be on an active call at the same time.
• Move the cordless handset closer to the base. You might have moved
out of range.
• Ensure that the base is powered up.
• Place the cordless handset in base cradle for 1 minute to allow the
cordless handset and base to resynchronize channels.
• If the cordless handset is in its base and the charging light does not
come on, refer to the charge light is off in troubleshooting guide.
• Reset the base. Unplug the unit’s electrical power. Wait for 15 seconds
then plug it back in. Allow up to one minute for the cordless handset
and base to reset.
• Other electronic products can cause interference with your cordless
phone. Try installing your phone as far away from these types of elec
tronic devices as possible: wireless routers, radios, radio towers, page
towers, cell phones, intercoms, room monitors, televisions, personal
computers, kitchen appliances and cordless phones.
Jul 16, 2009 | GE 29897GE1 Corded Phone
Unable to talk on two handsets at same time when receiving a call
Unfortunately that is the untold story about cordless phones they only have the capability of 1 open line be it the handset or or the base. There are some very pricey multi line systems, I have the same system bought two extra handsets and found out too late that I can only use them one at a time! Sorry probably not the answer you were looking for but thats the reality...
May 22, 2009 | GE 25942GE2 Cordless Phone System
Model 25922 5.8 GHZ Cordless phone with one main phone and two extras
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ge Telephone Solutions
Handset can not link.
• If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
No dial tone
• Check or repeat installation steps
• Make sure the base power cord is connected to a working electrical outlet.
• Make sure the telephone line cord is connected to the base unit and the modular phone jack?
• Disconnect the base from the wall phone jack and connect another phone to the same jack. If there is no dial tone on the second phone, the problem might be your wiring or local service.
• The handset might be out of range of the base. Move closer to the base.
• Make sure the battery is properly charged (for 16 hours).
• Ensure the battery pack is installed correctly.
• Did the handset beep when you pressed the TALK/CALL BACK button? Did the in use indicator come on? The battery may need to be charged.
http://www.home-electronics.net/ge/pc/IB/25922GE2_IB.pdf
Sep 02, 2008 | GE 26998GE1 Cordless Phone
Phone problem
I lost my manual for my GE 5.8 cordless gigahertz phone, and don't know how to program numbers in it. Can you please help me out?
Nov 30, 2007 | GE 25952 Cordless Phone
Handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Nov 17, 2007 | Xact Communication XG2200 Cordless Phone
Cordless Handsets don't work
in manual it states that you need to give permission on corded base for handset to link to cordless phone.
Oct 18, 2007 | GE 25881EE3 Phone
GE 25881EE3 Phone Logo
589 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
