Philips 60PW9363 60 in. Rear Projection Television, red sideways hourglass
Hi - can you give me any more info on your fix for the sideways hourglass and part #'s for the IC's with URL's where to buy them?
Thanx
  • 8,617 Answers
You can get the Kit at the following link which contains both ICs and the 12 Convergence resistors plus free instructions on how to do the repair. Its listed under their Convergence repair kit category and its called the DPTV305 - DPTV345 convergence repair kit. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Nov 24, 2008
Color and conversion problem with a pinched screen
Bad convergence amp ICs will have picture looking like hourglass in 2 or 3 colors. And narrow width and/or height.
Apr 02, 2014 | Philips Magnavox 9P6034C 60" Rear...
My Panasonic PT53WX52F has a sideways hourglass picture with the green scroll running in an arc with the same red scroll running straight across. Is this the convergence chip you talk about?
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 23, 2009 | Panasonic PT-53WX52 53" Rear Projection...
Red sideways hourglass
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jul 20, 2008 | Philips 60PW9363 60" Rear Projection...
Magnavox 51mp392h
replace the convergence ICs STK392-120 you will need both of them also check the 6.8 ohm resistors right next to the ICs as often 1 or 2 of them burn open. You should be able to notice the discoloration in the center of the resistors.
Mar 11, 2008 | Philips 60PP9202 60" Rear Projection...
Help!
problem would lie on convergence board, usually two big STK ics and resistors
Nov 14, 2007 | Zenith IQB50M90W 50" Rear Projection...
Zenith 50 In Rear Projection Hour Glass
My picture is a double image and has a sideways hourglass on the screen. Please help me!
Oct 08, 2007 | Zenith IQB50M90W 50" Rear Projection...
Hourglass Shape
Yes check for fluid leakage and see if the crt's are leaking fluid down on board. if so you have to change some caps any that got wet. If not wet at all then something that was fix maybe has a solder bridge on it look carefully and see if anything out of place
Oct 30, 2006 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
