Question about HP PSC 1410v All-in-One Printer
This HP PSC 1410v was a desplay model.
When I turn it on after a few seconds the "on", "check paper", check print cartage", "black start copy" and "color start copy" lights all blink. The print head never moves in this printer even when I open the print head access door but the scanner moves. I think that its in a safe/demo mode. I had a electronics repair shop back in the 90's. I know how to replace parts and work on electronics safely without getting zapped. I am just terrible at troubleshooting.
    Problem Solver:
  • 18 Answers
The manual is available online at http://h10032.www1.hp.com/ctg/Manual/c00364973.pdf It appears that you may have purchased a dud printer. The manual claims "The device has a fatal error."
Posted on Jan 14, 2007
SOURCE:
My HP psc1315 will not turn on. Some of the
To be able to understand the problem, you should give extra info about the lights.
Please find the information below about the status lights that provide information about error conditions of your printer. But first you need to install the driver for your operating system. The drivers are necessary to print documents and scan images. These drivers must be installed to use the print and scan features.
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HP PSC.
2 Turn your HP PSC off and on by disconnecting the power cord and reconnecting.
Problem 1: “ON” light is on, “check paper” light is blinking and “check print cartridge light” is off .
Explanation 1: The paper tray is empty, the HP psc has a paper jam, or the paper size setting and paper in paper tray are not the same.
Solution 1:
• Load paper, or remove thepaper jam.
• Change paper in paper tray to correct size.
• Change paper size on the computer software.
Then press On/ Resume to continue.
NOT : PLS SEE THE NEXT MESSAGE. CONTINUED AS THE COMMENTS BELOW:
Mar 31, 2010 | HP PSC 1315 All-In-One InkJet Printer
I ran out of paper and I turned off the printer and cancelled the print job. Now the printer will not turn on and the computer says the printer is off-line. What's up? It is an hp PSC 1410v
May be your driver problem uninstall driver and restart computer.
Reinstall Printer driver.
If not solve need to replace PCA Main Logic Borad
Thanks
Nov 30, 2009 | HP PSC 1410v All-in-One Printer
How do I get a alingment test
HP PSC 1200 and 1300 series:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
Jan 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
Wrong cartridge?
Doubled check the cartridge numbers and that they match what is on the printer. If no match get correct ones.
Oct 24, 2008 | HP PSC 1410v All-in-One Printer
Check print cartridge error
Try pushing it gently using some pressure. I had the same problem and it got solved using a little push.
Aug 27, 2008 | HP PSC 1210 All-In-One InkJet Printer
Problem scanning or copying in color.
if your cartages are ok then ckeck the colour print from pc if it is ok then clean ccd and if the problem will also come then replace scanner cable and after that if problem will also come replace scanner ccd
Jun 20, 2008 | HP PSC 2210 All-In-One InkJet Printer
Want print
I have a HP PSC 1410 printer. All of a sudden in the morning when i turned on the printer all the lights on the printer started blinking and keeps blinking. E appears on the copies LED. What could be the problem. I have even switched off the printer and turned back on but the problem remains.
May 22, 2008 | HP PSC 1410v All-in-One Printer
HP PSC 1410
if the ink on paper is sporadic mostly the black inkjet print catridge only needs replacement.
May 18, 2008 | HP PSC 1410v All-in-One Printer
Hp psc 1410v
Could be a number of things. I would try looking in printer settings first. Click on your printer, go to properties and check all settings, it may be set to do this or similar. If no go, try uninstalling and reinstalling it, or just turning it off and unplugging, replugging and turn on again can often reset irregulariites. Also try resetting default printer settings too.
Apr 07, 2007 | HP PSC 1410v All-in-One Printer
HP PSC 1410v All-in-One Printer Logo
83 people viewed this question
Clive
Clive
Thomas F. Schneider
