Question about Kenmore 63942 Dryer
Dryer has gas smell, whirlpool lgn 2000w gas dryer
I have made sure there was no obstructions in vents, no leaks from gas service to dryer gas pipe. if you have the gas shut off valve on & run your clothes on air , tumble only(not on heat settings), i do not smell the gas. i looked inside the peek hole in front when i turned dryer on heat settings & the flame burns yellowish blue, not consistant one way or another, when it is on heat temps. it smells like burnt gas. can you help?
thank you,
  • 706 Answers
Hello Tuna59,
I would strongly encourage you to identify the source of the gas leak as soon as possible. To do this, you can buy a product at most home depot or lowes department stores called SNOOP.. It is in essence..soapy water with a dauber in the cap. You use it by dunking the dauber in the solution and then putting the solution over gas piping joints. If it bubbles up at all..chances are that is where you have a small leak. You may or may not want to tackle that repair yourself since it poses personal risk if you don't know what you are doing. A build up of gas vapor in a confined space is very very dangerous and only needs a small ignition source to explode so please be careful. Probably a good idea to do all your troubleshooting ( if you decide to do this on your own ) with the windows open in that area. Do not use a fan or any other ignition source to move air/gas. Be careful.. and good luck...
Regards,
Rick
Posted on Nov 24, 2008
Gas Dryer wont stay lit.
It may be your dryer vent piping. If the piping from the dryer to the outside of the house is clogged with lint (which happens periodically) the dryer cannot get rid of the heat generated by the gas burner. When the temperature reaches a certain level the high limit switch opens and shuts the burner off. The switch closes again after the dryer cools down. Check the lint filter and all the vent piping for any obstructions and clean out thoroughly. This should solve your problem. Hope this helps.
Jan 14, 2014 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
I have a Kenmore 600 series gas dryer it has stopped heating. When you first turn it on it heats right up like it should then after jus a min the heat stops and it wont blow any more heat what could it be?
The majority of the time this problem is because the dryer vent is plugged. Remove the vent hose or pipe and clean it out, removing all lint buildup. Check the damper door where the dryer vents outside for obstruction. Make sure your lint filter and the area it goes into are clean as well. This will fix the problem 9 times out of 10.
Aug 02, 2013 | Whirlpool LGR3624JQ Gas Dryer
My dryer panel is blinking F70 and smells of gas
F70 code is warning you that the exhaust vent airflow is insufficient.
  • Check the exhaust hose in the rear of the machine and make sure it it not crushed or kinked. The vent pipe should be rigid metal not flexible foil or flexible plastic.
  • If using dryer sheets, rinse the lint filter with hot water to remove filmy residue that can restrict airflow through the filter
  • Inspect the outside vent hood for any blockages.
  • The exhaust system may need cleaning. Cleaning kits are available at most home improvement centers.
May 06, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Slow drying times
Check these things:
* The length of the dryer pipe and especially the wall flapper to be sure it moves ok and that it is not blocked by something
* Check the dryer vent line to be sure it isn't kinked somehere
* Check the dryer vent fan itself to be sure it is clean and not clogged or obstructed (I'm assuming it works)
* If all ok, you may have a bad thermostat or sensor that is causing the unit to turn off the heat prematurely
* Make sure the dryer isn't overloaded
May 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Smelling co2 around tank, replaced ventilation but still smell co2? need to see if there is a special way to install ventilation (model # whirlpool fg1f4040s3nov) gas water heater
You may be smelling other products of combustion but CO2 is a color-less/smell-less gas. A water heater should be vented thru 4" vent pipe to either a chimney or a wye which joins it with another appliance and a larger(size must be calculated) connector which connects to the chimney. There can be no reductions in size as you travel toward the chimney, and all pipe must slope at least 1/4"/foot up toward the chimney. Single wall vent pipe can be used unless it is less than 6" from anything flammable in which case type "B" vent may be used with a clearance of down to 1". If all this is correct your chimney may be over-sized or obstructed. Proper venting can be very complicated and technical and takes up most of most installation manuals for any fossil fuel appliance.
Pleas rate my answer!
Mar 25, 2009 | Whirlpool Water Heaters
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
Dryer is getting hot but clothes are not drying
You have a vent problem. Eliminate all (if possible) flex duct (replacing with ridged aluminum pipe and aluminum elbows). Clean lint out of remaining vent pipe. Make sure vent is not crushed or obstructed, especially behind the dryer. If possible, make sure outside vent termination is not a two inch opening. (you want a full 4 inches)
Nov 10, 2008 | Frigidaire GLGQ2152ES Gas Dryer
Kenmore 63942 Dryer Logo
135 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
