Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
Feed dogs not feeding the material
I have tried raising and lower feed dogs, and have had no sucess getting
material to feed for more than an inch or two, than it stays in one place.
This is actually a Kenmore 16221, not listed in list. I just bought it last week.
  • babs_root Nov 24, 2008
    The machine was brand new, never been used. I tried calling the Kenmore hotline. No one returned my call. I returned the machine, and bought a cheaper model, that wasn't discontinued. It works great. I would have liked to have the machine with more options, but I needed the machine right
    away. Thanks for trying to help me, I appreciate it.
    Babs
  • Kenmore Master
  • 1,388 Answers
Is this a second hand machine ?
Is the stitch length selector set to > 1
Remove the needleplate and clean between teeth of feeddogs if it has been a while since this has been done, old lint will impede feeding.
Presser foot tension for general work needs to be set at 3, or the chromed button pushed down to the grooved line, depending on machine.
If new, call the dealer where you bought it and speak to them.
Posted on Nov 24, 2008
Feed dogs lowered can't raise material not feeding thru
Is your machine mechanical? If so, sounds like the feed dogs are stuck in the lowered position. Needs good cleaning and oiling.
Perhaps this will help:
The feed dog knob won turn don think anything is broken haven used the...
Dec 30, 2015 | Sewing Machines
How do I raise the feed dogs
Make sure that your top and bobbin thread are the same and that the tension is set correctly. Then, be sure that the bobbin is put in correctly. If this happens when you are starting on an edge of your material, try putting a piece of material or even a piece of paper, like typing paper, under the edge of the material and sew a little beyond that and then onto your material. You can tear it off later. It gives stability to the edge of the material and should alleviate the problem. I hate when that happens! And, last but not least, be sure you are using the right needle. I love the ballpoint needles for most sewing projects.
Dec 30, 2015 | Baby Lock Evolve
Raise and lower the feed dogs
the feed dogs are the saw toothed piece under the press foot
they go down move forward raise up move back in time with the needle to pull the material through for the next stitch
the amount of movement ( stitch length) is set by the position of the forward and reverse lever/ knob
Dec 10, 2015 | Sewing Machines
My feed dogs will not pull my material through.
Check to be sure you have not inadvertently dropped the feed dogs on your machine. Dropped feed dogs are used for 'darning' or 'free motion quilting.' Below is info from Troubleshooting Manual:
Fabric does not feed through the machine
The feed dogs are lowered. Use the feed dog position switch to raise the feed dogs. 81
The stitches are too close together. Lengthen the stitch length. 42
The wrong presser foot was used. Attach the correct presser foot. 179
The needle is bent or blunt. Replace the needle with a new one. 34
The thread is tangled. Use scissors, etc., to cut the tangled thread and remove it from the race, etc.
Apr 11, 2015 | Baby Lock Esante
My sewing machine will not feed the material through
Are your feed dogs lowered? If so simply raise them. You should have a switch to do this. Sometimes it's located on the back of your machine almost directly behind the feed dogs.
Sep 30, 2014 | Sewing Machines
Feed dog on singer m756 won't pop up
If this is a combo embroidery and sewing machine, the feed dogs have a switch to raise or lower them. If this is just a sewing machine, your feed dog linkage may be broken.
Jul 15, 2014 | Singer Sewing Machines
My bernina 1030 won't feed material
Make sure the feed dogs are in the raised position and that the presser foot has been lowered before beginning to stitch.
Feb 11, 2013 | Sewing Machines
Machine will not move material under pressure foot. Thread get all bound up like tension my be too tight!
is stitch length setting correct, should be 2.5 for straight stitch. are feed dogs lowered for some reason? raise pressure foot and manually turn flywheel towards you while watching feed dogs. do they move up backwards and down? sounds like they are not feeding fabric through. check manual for how to raise and lower feeddogs if they appear to be down. sometimes its a button on base front or back of freearm. hope this helps out a little
Jun 06, 2011 | Sewing Machines
Feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Oct 27, 2008 | Husqvarna Viking 1
Feed doesn't feed Singer 560
there should be a control to raise or lower the feed dogs, lower to stipple and high to sew normal. it sounds like you may have lowered them
May 07, 2008 | Singer 5050 Mechanical Sewing Machine
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
187 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
