Question about Pioneer DVR-110D DVD RW Dual Layer Burner
Pioneer dvd-rw dvr110D 1.08 can't burn dvd
Hi there, I bought these dvd-rw and installed it in my ibm x205 computer. I swicthed to slave since there's an existing cd-rom drive in the pc. The pc recognize it and reads cd's, but when to use it as dvd burner, it can't do its job. I tried it with burn4free and nero. Do I need to install driver? and what it should be?What could have been the problem? anyone pls help.
4 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: DVD+RW compatibility
your dvd only writes to dvd-r and dvd-rw, but writes to both cdr + and - r/rw. To confirm it go into nero tools and nero info tools and all the ticks in the boxes are what your drive supports
Posted on Apr 18, 2007
SOURCE: I can't write DVD with my Pioneer DVR-107D DVD±RW
Download install and run Imgburn_2.4.1.0 as a TEST.
My Drive did not work with Nero 7 but was fine with the latter.
This proves Nero can be quirky with some drives.
Posted on Jul 14, 2008
  • 224 Answers
SOURCE: computer reading pioneer dvd rw burner as a cd rom not as a dvd r
Please select the recorder in drop down menu, once you select your DVD writer, you will be able to burn movies.
Posted on Sep 09, 2009
I Firmware problem!!
check the jumpers are on master slave or both on CS Cable Select
Jul 15, 2010 | Dell Dimension 1100 PC Desktop
Pioneer DVR-K17 won't burn at 8X ! !
Maybe the DVD not support this speed!
Feb 05, 2018 | Pioneer DVR-107D DVD±RW Burner
Cannot copy files from computer to Pioneer DVD-RW DVR-112D
Try using another burner use Nero burning ROM or Roxio Creator DE.
Nov 17, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Burned DVDs play on PC but won't play on home player. I have 3 PC (2HPs and 1 Parts built),running XP home, pro, media. I bought 2 Samsung SH-S182 DVD±RW Dual Layer Burner, and have tried them on all 3...
Nero 6 and 7 does not provides us the facilitiy of burning the DVD in appropriate DVD Format. Instead it burns the DVD in the normal DATA Format, which is not supportable by our DVD Player. To play the DVD in our DVD Player we should burn the DVD in the appropriate DVD Burner which itself converts the extension of the movie and make it proper for a DVD Player to read it. It also adds some files to the DVD which is sometimes used by the dvd player in running the DVD.
Thank You
Vinay Ramani
INDIA
Oct 07, 2008 | Ahead Software Nero 6 Ultra Edition...
Pioneer dvd-rw dvr k15ra
Imy burner will burn if I go into MY COMPUTER than into MY E drive but the auto burn will not work. I do have 1dvd click and ashampoo on the computer as well, but when I put a disc into the computer it will not automtically work. I was wondering if the above programs are stopping the auto play on it or what? The burner works fine if I go to the E drive and install o burn it that way, is there some kind of a setting or something that went out of wack??
Aug 16, 2008 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
What brand of media are you using?
You are burning at 2x because that is the highest that this drive supports.
You would also want to instruct Nero to Verify by ticking the check box and either finalize disc or make it mulitsession, if your burner supports multisession DVDs
Regards,
Worldvet
Jun 13, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneer DVD-RW DVR-111d instruction manual
The manual likely is at the Pioneer website. But why do you need it? These drives stick in your computer pretty easily, and only function if you have a good DVD burning program installed. Did it come with an installation CD? Your burning program may be on that. If you run into trouble, just call Pioneer--they owe it to you.
Mar 23, 2008 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Pioneer dvd-rw dvr-
have you connected the 4 pin molex plug from the computer mainboard to the drive ?
is the IDE Cable correctly fitted ?
did you set the jumper connector on the rear of the drive to Master Or Slave ? if you are sharing the cable with a hard-drive, and the hard-drive jumper is set to slave, then the dvd will have to be set As Master ( otherwise they conflict ) or only 1 device will be recognised.
This should Solve your problem here.
Mike @ Compurepair.
Feb 19, 2008 | Pioneer DVR-112D Burner
Jumper
Does the cord going to your CD-RW hasve asnothe plug further down the line most computers can connect 2 cd type drives!!!
Jan 02, 2008 | Pioneer (dvr-a06u) DVD±RW Burner
Optorite DD0401 DVD +/- RW
Right click My computer>Explore, and see if your dvd writer is showing as a DVD RW drive and not a CD Drive, then come back
Nov 14, 2006 | Optorite (dd0401) DVD±RW Burner
Pioneer DVR-110D DVD RW Dual Layer Burner Logo
67 people viewed this question
Top Pioneer Computers & Internet Experts
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
