Question about Canon imageRUNNER 5570 Copier
Stuck on ''performance shutdown screen''
Our copier at work is stuck on the "performance shutdown screen" and the copeir's keys are unresponsive to start, stop or reset.
Is there a way to fix this our should I contact the local help disk here?
Thanks.
  • muiguelarcan Feb 05, 2009
    I do to painel in secret mode and the only we see black page wthats we are do
Error E000410
Posted on Feb 07, 2009
  • vmittal7832 Feb 07, 2009
    error E000410
    ir 5570 conon service manual
PEA is on the screen and no keys work
stuck splash screen Cash Registers & POS Equipment ...
www.fixya.com > Forum > Tags > stuck splash screen
Ask your stuck splash screen cash register and pos equipment questions. ... ...screen displays PE, machine stops working Register tape won't feed, turning it off then back on ... the register is stuck and is displaying PEA Perfom a master reset ... Screenstuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
delay stuck Cash Registers & POS Equipment Questions ...
www.fixya.com > Forum > Tags > delay stuck
Cash Registers & POS Equipment delay stuck questions and answers. Ask your delay stuck ... Also if that doesn't work and its a dual com, make sure its set to dial. coppy ... Ad ... the register is stuck and is displaying PEA Perfom a master reset ...Screen stuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
Hi There my SAM4S is showing PEA on the screen. All the ...
Nov 26, 2015 | Retail Supplies
I HAVE AN KYOCERA KM5035 COPEIR M/C BUT I am unable to reset my m/c as you have said the solution press twice10871087 for service mode and then163...
IF SOME KEYS NOT WORKING THAT MEAN YOU HAVE TO BLOW THE KEYS FIRST . MAY BE SOME KEYS ARE STUCK . IF THAT DOES NOT WORK I AM AFRAIED YOU HAVE TO OPEN THE KEYS PANNEL MAYBE ONE PRESS ELEMENT OR MORE ARE DAMEGED.IF SO YOU HAVE TO REPLACE IT.
Aug 19, 2015 | Kyocera Mita Office Equipment & Supplies
Affinity dryer throwing a E 68 code what is first step to fix
Hello Lori, thank you for your post!
If you are getting an error code 68 on your Frigidaire dryer, it usually indicates that one of the keys (buttons) is stuck closed (active). You may enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps! - Z
Sep 01, 2014 | Frigidaire Dryers
What causes LEQ70000eGO dryer to continue to be on but dryer does not run. code E68
Hello Tam, thank you for allowing me to assist you!
If you are getting an error code E68 on your Frigidaire dryer (LEQ7000EG0), it usually indicates that one of the keys (buttons) is stuck closed (active). Enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing after proper diagnosis. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps! - Z
May 19, 2014 | Electrolux Dryers
Touch Screen
`HI, try to see if one one of the keys on the control panel
is not stuck. If one of the keys is stuck you will not be able to
use the touch screen
Mar 10, 2014 | Toshiba E-Studio 456 Copier
My i phone 4 get stucked at least 1 in every 45 days
if it gets stuck force reboot Hold power and home button down for 10 seconds then turn it back on. For performance regularly shutdown open apps double click the Home button. Apps pop up down the bottom, hold finger on one and they all begin to wiggle, click the X in the corner of all the open apps.
Nov 14, 2013 | Apple Iphone 4s I Phone 4 S Factory...
All i do is click shut down but it doesnt do anything at all. what should i do?
CTL,ALT.DEL select task manager under there you should see that there is a program that is not shutting down thus causing your issue. You need to shut it down before shutting down the computer again. Otherwise hold down the power button to FORCE SHUTDOWN.
Thanks and do be considerate when leaving feedback and ratings.
May 29, 2010 | Dell Inspiron Mini 10 Notebook
My Acer Aspire AS4315-2004 Notebook screen display is very unstable. shaking badly and opening all sorts of windows . Cannot shutdown as screen does not allow hitting the shutdown icon with the mouse....
CHECK OUT YOUR KEYBOARD, COULD BE SOME KEYS ARE NOW STUCK. IF POSSIBLE USE EXTERNAL USB KEYBOARD TO IDNENITFY THE MAIN COURSE.....OR ON CONTROL PANEL ON YOUR ONSCREEN KEYBOARD.
Oct 16, 2009 | Acer Aspire 4315 Notebook
WAX INK STUCK IN A XEROX 8560 MFP
If you lost power or unplugged this unit without first allowing it to perform a full shutdown, you are most likely seeing the wax ink 'dumped' internally. You'll need to contact a certified Xerox technician in order to get the unit cleaned and repaired.
Sep 03, 2009 | Xerox Office Equipment & Supplies
Start menu wont show up
application softwares &system software in start menu
Feb 02, 2009 | Microsoft Windows 98 for PC
Canon imageRUNNER 5570 Copier Logo
97 people viewed this question
old marine
old marine
Corne Viljoen
