Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
The door on my dishwasher will not close
The dishwasher is loaded properly, nothing is in the way to keep it from closing, but the door will not close.
Frigidaire
154607401 this is the # inside the dishwasher
Thanks,
  • Anonymous Mar 24, 2014
    Door won't close
  • 1,031 Answers
There are a few problems that can occur with the diswasher door assembly. These usually involve the latching mechanism, the door seal, the counterbalance spring assembly or the hinges. 1) The door latch plate can occasionally become out of alignment. Some door latch plates are adjustable, some aren't. If yours is adjustable, try loosening the retaining screws and repositioning the plate. It's trial-and-error, so have a lot of patience. If this doesn't work, then the latch needs replacing.
2) A new dishwasher or a newly installed door seal can be difficult to close for a while until the seal softens and compresses over time. You can try adjusting the latch, if possible.
3) If the door feels unusually heavy, there could be a problem with the counterbalance spring assembly. These counterbalance assemblies allow the door to open and close easier and are held by two springs. On some dishwasher models, holes are positioned in line so you can re-tension the springs by moving the spring hooks to other tensioning holes. If any of these springs break, they will need to be replaced as a pair.
4) The door hinges might be bent. They can seldom be adequately fixed and should be replaced.
hope this helps
Posted on Nov 24, 2008
Kickplate on model KUDG25SH
turn off breaker to it leave one minute and turn back on also make sure door is closed tight and nothing is fouling it from proper closing .
Jul 13, 2014 | KitchenAid 24 in. KUDS01FLBL Built-in...
Press START and nothing happens
yes the door has a safety switch that will keep the machine from starting, this is most likely the problem.
Aug 12, 2008 | Kenmore 15762 Dishwasher
I start the dishwasher and it does nothing and lights do not turn on either
When your dishwasher won't start, it could be a problem with your electrical panel or the door might not be closing properly.
Check your household electrical panel for a tripped breaker or blown fuse. Also check to make sure the door latches closed properly.
For additional troubleshooting steps you can take and things you can do, read Dishwasher won't start for more suggestions. I hope this helps!
Aug 02, 2012 | Kenmore Dishwashers
Doesn't close tight enough to start
It sounds like your door-closed sensor (a microswitch) is out-of-adjustment. If you can locate this sensor, try gluing a tiny piece of plastic or wood to it. This will do the same thing as pushing really ******* the door and allow your dishwasher to operate normally.
Dec 26, 2017 | Bosch SHE5AL02UC Builtin Dishwasher
I loaded my dishwasher lastnight as normal closed it and hit the start button and nothing happend. its like it has no power! what can i try before calling someone?
first check electrical supply,second check switch continuity,3rd check door switch or reed switch if contact properly.
Aug 12, 2010 | Dishwashers
The door won't close completely
Hi, Check for the following whenever you have problems in door
Latch: The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Apr 12, 2010 | Frigidaire Professional Series 24 in....
Door leaking
According to manufacturers, the DW may leak for three reasons:
1. Door not closed properly. Be sure the door closes and the door gasket is not damaged. Inspect the gasket closely, sometimes silverware damages it.
2. Use the appropriate Dishwasher soap. Don't use regular soap. If the dwsoap is too old, replace it.
3. Water sensor not working and the dw is overfilling. Be sure the float switch is working properly and nothing obstructs it.
Dec 18, 2009 | Maytag Dishwashers
Door won't close wont lock closed
Check the following if you have problem with your doors:
1)The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
2)Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
3)The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
4)If your dishwasher is new or if you have just replaced a door seal the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 03, 2009 | Westinghouse Dishwashers
Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Sep 23, 2008 | Asko D1996SS Built-in Dishwasher
Kenmore dishwasher 16182 won't start
make sure the door is closing properly. if the door is closing properly you could have a door switch problem.there may be other problems but i would check the door first.
Mar 23, 2007 | Kenmore 24 in. 16182 / 16189 Built-in...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
1,605 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
