Screen issue:
It sounds like either the lcd screen or video card inside the computer
is bad. To isolate the problem try connecting an external monitor to the
laptop. It can be any kind of monitor even the
old big
fat crt monitors as long as it has a vga cable to connect to your
computer's
vga port. If the external monitor displays ok that proves your video
card is ok and your lcd screen is the problem. If the external monitor
displays the black or white screen like your lcd screen then your video
card inside the computer is bad. The video will
show on most systems when you reboot without you having to do anything.
Some
systems will require you to hit the FN (Function key) + F1 thru F12.
Hold
down the FN key then hit the correct key for displaying on the monitor
(F1 thru
F12). The correct key will normally have CRT/LCD on it or it will have
the icon of a display.
Laptop hot:
Some laptops and the ac adapter get very hot. If the laptop is not
shutting down, then it is not overheating, so don't worry about it. You
can buy a laptop cooling pad that has fans on it and it plugs into one
of the usb ports on the laptop. The laptop sits on it to keep cooler.
Your battery is probably dead so that is why you can only power it up
using the ac adapter power cord. Once the power cord is removed, the
laptop will turn off. Batteries only have a useful life, and after
that, they have to be replaced.
simple. clear the CMOS by using clear cmos jumper setting or remove the cmos battery and put it again and then change the bios settings as per ur machine configuration.
SOURCE: computer not booting
Unfortunately it sounds like the processor fried. These are very prone to heat degradation.
Link to computer gate
Link2
Link 2 is to Geeks.com
Link 3 Take your pick
Your board supports Northwood/Williamette processors with HT
in 400/533/800 Front Side Bus
SOURCE: Computer turns on, but there is no display on monitor.
Go to the BIOS in Advanced - Chipset
Change the Graphic Adapter Priority setting.
SOURCE: laptop motherboard
could be bad screen ok or video controller will have to have parts to test
