Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
Lg 150 cm rear projection
I'm having problems with my lg rear projection, blue color started to come out on the bottom sides of the tv, the more we use it the color blue spreads. It's already covering 80% of the screen. It's still watchable but it's not as clear as before most of the color of the tv is gone, I got an electrician to have a look at it, he said i have to change the whole engine, not quite sure what he meant by that. I was told by him that the parts is no longer available to purchase.
  • 1 more comment
  • EddyO Nov 18, 2007
    I have the same TV and the same problem, the blue haze in lower right corner takes up about 10% of screen and appears to be growing.
  • Anonymous Jan 03, 2008
    I HAVE THE SAME PROBLEM BLUE COLOURS LIKE PAINT SPLASHES APPEARED ON MY SCREEN FOR ABOUT TWO MONTHS NOW I HAVE TURNED THE POWER OFF COMPLETELY A FEW TIMES BUT IT JUST GET WORST
  • Bartman1 Feb 10, 2008
    I also have the same problem slowly getting worst covers about 30% of the screen
This is the engine problem cause by the blue lcd inside the engine if you can find the blue lcd you still have to do the converion. by lg technician
Posted on Dec 31, 2006
SOURCE:
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Why is my LG LCD rear projection TV screen turning blue?
if the blue color has a blobby appearance than its an optic block (color engine)failure take your model number and check ebay for replacement
Dec 29, 2010 | LG Televison & Video
I have an LG Rear projection TV Model No. MW-60SZ12, it has patches of blue tinge through the bottom of the screen, i have replaced the globe and the picture has improved but i still have these blue...
your optic engine is stuffed! the blue ,green & red optics are glued into place instead of screwed.after time this glue fails and the colours fade onto the screen. very common problem with this model.
Jul 20, 2010 | LG Televison & Video
Hello, I have an LG lcd rear projection tv and parts of the screen are turning blue, do you think it's just the bulb or the light engine?
Hey there first of all your tv is a lcd rear projection set, this tv's don't have a light engine system, they use a optical block
whats happpening is that one of your lcd chips is burning out and this problem will start to get worst, to be honest with you it's very hard to purchase just the LCD chips, you need to buy the optical block to fix your set, also the bulb has nothing to do with the color the bulb just shoots out light.
please rate this solution!!!!!
Mar 10, 2010 | LG RU-52SZ30 52" Rear Projection...
Blue escreen
Call LG they bought zenith and there is a class action suit so you can get a replacement or repair refund from LG
Jan 15, 2010 | Zenith D60WLCD 60" Rear Projection...
Our L.G tv ( model RT-44NA11T)has color problems.
If your TV is not DLP, replace STK ICs convergence.will have part # ON THEM . Projection has 3 tubes a red/ a blue and a green TUBE ---DLP has 1 Lamp.
Sep 18, 2009 | LG Televison & Video
Blue dots and blue screen on Hitatchi 50"
Bad Light Engine Call UED for rebulit one 1-800-648-6657 They are not cheap.
Dec 26, 2008 | LG RU-44SZ51D 44" Rear Projection...
52" LG LCD rear projection screen blue discoloration
bonsoir!ce que vous avez ici c'est un probleme de light engine ;c'est surement un le filtre bleu qui est brule et cette tache va remplir tout l'ecran apres,il faut contacter lg et manifester parceque le light engine coute tres cher 900 us
Oct 17, 2008 | RCA HD50LPW175 50" HDTV
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
116 people viewed this question
Steve Allison
Steve Allison
