Question about Kidde Nighthawk Combo Gas/co Detector
What does an err code E03 mean?
A kidde KN-COEG-3 nighthawk plug- in carbon monoxide and explosive gas w/battery backup beeps every 30 sec Err if I press peak level button I get E03 it has a new battery and is plugged in
  • meycro Nov 26, 2008
    Same problem.
  • adaperry Dec 26, 2008
    Had the same problem 6 months after product was purchased. Huge disappointment.
  • 7 Answers
Malfunction signal - Component failure. An intermittent "chirping" alarm will sound every 30 seconds, and an "Err" message will appear on the digital display. The only solution is to discard it entirely and replace with a new gas & carbon monoxide alarm.
Posted on Nov 10, 2012
  • 3 Answers
Correct. Intermittent beeping is a sign of "component failure". Time for a new one.
Posted on Dec 25, 2008
    Genius:
  • 1,605 Answers
The sense is bad, unfoturally the unit need to be replaced.
Posted on Dec 02, 2008
My night hawk carbon monoxide reads L6. Then Err.
Lb (rather than L6) indicates a low battery. You need to replace the 9V battery in the carbon monoxide detector. The Err suggests an internal error but could just be due to the low battery.
If the Err persists after you replace the battery, press the peak level button (the right hand button) and check for an additional error code. If the Err message continues, replace the Night Hawk unit. If the unit is still under warranty, contact the manufacturer. Most of these units have a 10 year warranty. There are several models available from Kidde. The manual is available on the product site. For the KN-COPP-3 Night Hawk carbon monoxide detector, the documentation is available here: http://www.kidde.com/home-safety/en/us/products/fire-safety/co-alarms/kn-copp-3/ . Click on the Documents tab. The manual for the KN-COPP-3 999-0100 is here: http://www.utcccs-cdn.com/hvac/docs/2001/Public/06/User_Guide_KN-COPP-3_900-0100.pdf .
I hope this helps.
Dec 12, 2016 | Night Home Security
Kidde nighthawk carbon monoxide detector started beeping every 30 sec.pressed reset button on front beeping continued louder, put unit ouside in fresh air for few secs beeping stopped. I opened the...
Golding93, you could very well have elevated levels of CO in your home. You should leave your house immediately and call the fire department. However, if your CO alarm is 7 years old, it could also be the alarm's end-of-life warning. Regardless, you should definitely call the fire department to have everything checked out. If you need additional assistance with your CO alarm, please call our customer service line at 1-800-880-6788. Thanks for being a Kidde customer. We appreciate your business!
Crystal Robinson
PR Coordinator
Kidde
Dec 20, 2010 | Kidde Nighthawk Combo Gas/co Detector
Nighthawk carbon monoxide alarm model number KN-COPP-3 err beeping every 25-30 seconds, I replaced battery they still beep. They say to seek users guide, which can't be found. It seems to have started...
1. Change batteries.
2. Clean it.
3. Swap it with another location if you can.
If it still does not work properly consult the local fire dept. for free.
You may have to take it in repairs if all fails.
Nov 08, 2010 | Kidde Nighthawk Combo Gas/co Detector
Nighthawk carbon monoxide alarm model KN-COPP-3. ( ERR appears in the window, what does this mean ....
Readings You May See When Unit is AC Powered
Display Shows Alarm Sound Unit Status Recommended Action
Steady "Err" "Chirp" every Unit malfunctioning when Call KIDDE customer
and flashing dot 30 seconds AC powered service at 1-800-880-6788
Readings You May See When Unit is on Temporary Battery Backup
Flashing dot None Normal battery-only operation - Plug in to AC as soon as
unit will show reading only if it possible to conserve battery
senses CO
Flashing dot and "Chirp" every Unit malfunctioning when Call KIDDE customer
"Err" 30 seconds battery powered service at 1-800-880-6788
Hope this helps. Manual is here:
http://www.detectorsandalarms.com/images/pdf/Manual_KN-COPP-3_900-0100en.pdf
If this helps you resolve your problem, please consider giving a good rating and a quick thanks or good job.It will help me as well Thank you.
Oct 26, 2010 | Computers & Internet
My Kidde Nighthawk Carbon Monoxide detector was beeping shrilly and read gas. When pressed the reset button it read 221. Problem was it was sitting facedown in a box (i'd just taken it from my old...
A reading of 221 ppm carbon monoxide gas is a dangerous level that should be taken seriously. You could try a new battery and reset the detector. If in doubt, always err on the cautious side and have the apartment checked by a professional or by the local fire department.
A new carbon monoxide detector is a small investment that may prevent carbon monoxide poisoning or death.
Jul 22, 2010 | Kidde Nighthawk Combo Gas/co Detector
How can I shut off my Kidde carbon monoxide detector when beeping
Here is the link to the manual for your Kidde model KN-COB-LCB-A
Carbon Monoxide Detector. This may help you solve your issue.
You may find more related information on my website. If you need a replacement or you need to add additional Carbon Monoxide Detectors in other levels of your house, you can purchase them here.
This issue should be solved immediately, Carbon Monoxide Poisoning can only be avoided by making sure you have good working CO Detectors in your house, camp or recreational vehicle.
Jul 24, 2010 | Kidde Nighthawk Combo Gas/co Detector
My Kidde Model # KN-COEG-3 keeps going off and lists 217 now 205 now again 217 and this is with the door open and fresh air coming into my place ??
I took the following from the Kidde website. They only answer the phone Mon-Fri, from 8-5, EST. I checked it out because my almost new Kidde CO detector is showing an Error code.
The next time your carbon monoxide alarm has ERR on the display, push and hold the Peak Level button.You will see an E and an O followed by a number.Contact our hotline at 1-800-880-6788 and provide us the error code, along with the model number, assembly number and date of manufacture from the back of your unit.If your unit is under warranty, a replacement will be mailed to you.
Nov 21, 2009 | Kidde Nighthawk Combo Gas/co Detector
My CO detector is chirping every 30 seconds or so, there is no battery to change and receiving error code 09
depending on what model number you have .. if its a model kn-cosm-b then is actually has 3 AA batteries inside ... the model kn-cob-lcb-a, while it runs on 120 volts, still has a 9 volt battery inside .. in fact most models have a battery backup so that they still work if there is a power outage .. the chirp indeed tells you that the backup battery needs changing .. if you cant find the battery give us the model number and we can help ... sometimes they are hard to find ..
Nov 05, 2009 | Kidde Nighthawk Combo Gas/co Detector
Nighthawk carbon monoxide alarm model kn-copp-b
Here is a link to the manual, or you can call the consumer hotline at 1-800-880-6788
Nov 10, 2008 | Kidde Nighthawk Combo Gas/co Detector
Kidde Nighthawk Combo Gas/co Detector Logo
2,793 people viewed this question
Top Kidde Home Security Experts
john h
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
