Question about Soyo DYLT032D 32 in. LCD Television
I have a Rogers HD cable box and want to control my Soyo HDTV with it. I look in the Rogers manual but could not locate the device code. Can you tell me what it might be?
  • 3 Answers
First you have to know witch remote you have there is a 3 button witch has vcr tv and cbl at the top that one there press tv and select at the same time untill the light flashes 3 times release then enter 9-9-1 the pres the tv button untill the tv turns off if you have the newest 5 button remote you will press tv release press and hold setup untill light flash's 3 times then enter 9-9-1 light will flash once entered then press ch+ sevral times untill your tv turns off once tv turns off stop and press setup and that will lock the code inplace i hope that helps
Posted on Jul 23, 2009
Hdtv plug where is it?
on the back, beside the cable plug.
Sep 01, 2013 | Soyo DYLT032D 32 in. LCD Television
Programe sony rm-vl610 from rogers cable
This is the setup code for Rogers cable box. 0506
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jun 23, 2012 | Sony Televison & Video
How do i connect my directv box to my soyo tv #DYLT032D
  • If your DirecTV box supports HDTV then connect it using either an HDMI cable from the box to the TV (located on the back, labeled HDMI 1,2,3,etc.).
  • If the box is not an HDTV box then connect it with a RGB (red, green, blue) composite cable from the box to the TV.
  • If the RGB output is not on the ack of the box then connect using a standard coaxial cable.
[NOTE] In order for the quality of the picture to be HD, use the RGB for digital (Better), or the HDMI for High-def (Best)
Mar 02, 2011 | Soyo DYLT032D 32 in. LCD Television
I have recently gotten a Sharp AQUOS Quattron (LC52LE810UN). I have a rogers cable box with a RCA input, but the tv doesnt not have an direct RCA input. It has a input for an audio cable with a component...
Your TV is a High-Def TV (HDTV) therefore you need a Rogers cable box and service capable of High-Definition in order to get the HD resolution you paid for with the HDTV. HD video requires HDMI or component video cable connections. Standard RCA AV (yellow, white, red) will not show HD video.
Having said that, you may want to hookup a game or VCR to the TV and therefore you will need to get a cable known as an AV miniplug. It has RCA (3) on one end for the VCR for example and on the other end is a Mini-plug to connect to the HDTV (Sharp). This cable is like the ones used on camcorders such as Sony. Make sure you get a cable with the right ends as depicted in your manual on page 14.
You'll have to Google online for a supplier. Sparco.com had these cables but are out of stock currently.
Jan 17, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
HD Video Recorder - CEC connection with HDTV
My first question would be, Is your Panasonic HD recorder CEC compliant? CEC means Consumer Electronics Control. That simply allows for the consumer to have better control over their Home Theater set up through the connection of you HDMI cable from their remote control without programing the remote control for every single device that is connected. If your recorder is CEC compliant the television should have automatically recognize the recorder and control you recorder via remote control (I am assuming that your recorder is an HD Camcorder, since your description was very vague). Once you connect your HD camcorder to your panasonic tv the tv should have turned on switching to the correct input and the same for any other CEC comliant devices. If your Panasonic HD recorder is not CEC compliant the you would have to start viewing your recorder the old fashion way, by using the recorder remote control or if your Toshiba remote is universal punch those codes in so that you can control your devices that way. If that don't work, try a different HDMI input and select the input and make sure your recorder is set to output on you tv. Hope this helps.....before I forget, check out this site to learn more about Consumer Electronics Control (CEC) http://www.videsignline.com/howto/207400325
Nov 23, 2008 | Televison & Video
Have hd cable box to hdtv, need cable remote to control hdtv- no code
It can be solved, but you have to buy a universal remote, and not use the comcast remote.
http://www.iconnectdots.com/ctd/2007/05/targets_trutech.html
Oct 03, 2008 | TruTech PLV16190 Television
Tv 1080 signal not responding to cable to get hd format
i have iptv an we cant get this tv set up on it can you help me please
Aug 11, 2008 | Soyo Onyx DYLTO32D 32 in. LCD HDTV
Prive lcd tv remote codes
no manufacture has that brand in the code list. but soyo did come out with their own remote that will work satellite/cable boxes. Go on their website. www.soyo.com
May 28, 2008 | Soyo Atlas DYLT3212 32 in. HD-Ready LCD...
Device code for Samsung SMT-H3050 HD Cable Box
I use an old universal onkyo remote. 0035 Is a Panasonic code but worked the smt-h3050
Hope this helps
May 26, 2008 | Bose Cinemate Digital Home Theater System...
Need codes for electrohome lcd tv so i can program it with my rogers hd box
i'm thinking you want to control your tv with the rogers hd box remote.
here is the link please click on the Remote Control Code-Finder
link on it and find your remote.
http://www.rogershelp.com/DigitalCable-Ontario/category.php?id=YY-24
Apr 15, 2008 | Televison & Video
Soyo DYLT032D 32 in. LCD Television Logo
122 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Marvin
Marvin
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
