Hi we can not reduce the temp on our heating how do i go about this?
  • 30 Answers
You may have a bad thermostat. Is it digital or an older style? Is your furnace running and not shutting off even though your thermostat is not set to come on? Please Clarify
Posted on Nov 24, 2008
I install 2 new honeywell non programmable thermostats. The temp never reaches the setting temp. Always 5 to 8 degrees off. I can not get the furnace to heat the home over 70 degrees. Even set at 80. Any...
If the furnace is cycling on and off and not reaching temp there is a problem in the control circuit. If the thermostat is not satisfied the furnace should be running without shutting off in which case the capacity of the furnace is inadequate because of size or problems reducing the capacity. This could be caused by an increase in home size, poor air flow (dirty filter, loose fan belts, fan running slow, obstructions in the duct), dirty heat exchanger or burner, reduced gas flow, over temperature switch bad causing the burner to shut off early, or a few more technical reasons. You may do well to call a technician to troubleshoot this problem.
Feb 09, 2015 | Heating & Cooling
Done outside gummy inside
Hi.
I'm guessing that this is a cooking problem, so here goes.
If the food your cooking is done on the outside, but not done on the inside, then you have the temperature at the wrong settings.
Reduce to a lower temp, try with a new batch, and cook it for 50% longer at the lower temp: i.e. if it said 350 degrees for 30 minutes, then reduce to 300 and cook it for 45 minutes instead.
The longer time allows for the heat to penetrate and cook the middle, not just the outside.
I hope this helps you out, and good luck.
Mar 14, 2011 | Computers & Internet
Heater does seem to get very hot
Reduce your temp setting.And if you keep thermostat setting +5 from room temp and still it gives too hot, heating sensor problem. Replace it.
Dec 14, 2010 | Ruud Handler Air Conditioner
I turn the heat on sometimes it blows heat some times its just cool air.
Please keep your heat setting is maximum and then reduce. Some times if you keep +2 or +3 degree from room temp, frequent shut off heating will be there.
Dec 11, 2010 | Heating & Cooling
What is hte proper temp on a 2008 cobalt?
Ususally the thermostat opens at 195 to 200 degrees. Coolant and pressure allow normal temps to go to 230 to 240, and much higher under heat soak condition (unit turned off). Fans kick in near that temp. So, the engine needs to be that hot to be efficient and to have emission controls shift to normal... Also the high temprature prolongs engine life by forcing moisture from the oil.
Sep 26, 2010 | 2008 Chevrolet Cobalt
I have a delonghi oven. The grill element smokes violently as the element heats up. Does it need a replacement grill element?
no you dont need a new grill its just collecting fats from when you roasting and burning off when you initially heat the grill. if you use the grill more often it wont build up as much. covering the roast can reduce the saturation and perhaps a slightly lower temp will help reduce splattering.
Aug 02, 2010 | Ovens
Does my Bosch SHU3032UC have a heat booster?
The dishwasher has a built in instantaneous water heater, so even if the water feeding the d/w is cold the machine will heat it the the temp required for the cycle you have choosen. Reducing the temp will not effect the wash quality at all, in fact having a lower temp or cold water filling the machine will make the drying cycle at the end of the program more effective.
Hope this helps, please leave feedback.
Jul 27, 2010 | Bosch 24 in. SHU30 Built-in Dishwasher
1999 dodge dakota blows cold air at idle but heat warms up when revved. would like a solution to this heater problem. I live in alaska and need the heat to function properly. already flushed the heater...
Sounds as if the engine is not building up temp due to cooling system working. If engine temp gage is reading low try covering 1/3 of radiator with a piece of cardboard "Bumper side" to reduce the cooling effect.. just watch temp and out side temps if warming up outside or heavy driving remove the blocking to allow full cooling
Jan 22, 2010 | 1999 Dodge Dakota
Stoves new home fan assisted oven. do you reduce heating time and or temperature
It is usual to reduce temp and or time for a fan assisted oven, as opposed to a conventional convection oven.
Please rate my solution.
Thanks.
Nov 24, 2009 | Stoves Ovens
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
