Question about Toshiba Satellite A100-S8111TD Notebook
My Toshiba Satellite has a sounds problem
All things seems alright, the driver are working properly, And the audio in control panel are active. But when I try to play any music file the Media player is functiong well, but still there in not sound either from the Laptop is internal speakers, or even from the headphone one.
please hope to get your help on this matter.
Thanks
  • 103 Answers
Hi
your Machine has a volume control an the panel where your power switch for the computer is make sure it is increased to the max. thats if your are sure your drivers are working properly
thanks
Posted on Nov 24, 2008
    Sergeant:
    Champion:
  • 274 Answers
Make sure your volume controls are not muted and levels are midway.
Right Click on Speaker icon in lower right system tray and choose Open Volume Controls.
My toshiba microphone is not working
These are steps to ‘setup’ and ‘restore the "Audio Drivers.” Part (1) Go to the Control Panel, select "Hardware and Sound." In the next window, click on the "Sound" category; next select, "Manage audio devices... "Once the window open, select "Recording," click on the "active "Microphone," click on the "Configure button" make all necessary changes. Part (2) Click on the "Start" button, go to, and click in the (right, pane), the Control Panel. “Scroll to find, "Ease of Access (or) Speech Recognition Options.” Next, select Replace sound with visual cues." In the See also: (Category), click, on “Audio Devices click on the, 'Playback' button, select the 'Active' Speakers. Select, Configure to: "Audio channels" The (Speaker Setup) "wizard,” appear! Select (Test) click, the “Next” button. Follow the instructions. Part (3) Click 'Properties' change the "sound"(Level). Select 'Enhancements', "Apply" changes. “The (Advanced), “not recommended!” In, the (“Controller Information”) block, click on the, Properties to "update" Drivers. “Check to see if, Device usage: (enable) if not? “ Change it. Part (4) Next, go to the Properties to view: Device Usage: ("enable), "Update Driver." Note: Select buttons "OK" to all changes “Save and Apply!” Restart the computer "Did this solution help?” If so, "Helpful Rating Feedback," appreciated, thanks paul7of9"
Feb 25, 2010 | Toshiba Satellite L305-S5921 Notebook
Cannot access volume control toshiba notebook satellite
Hi, click start, click control panel, click sound and audio device, click audio tab, that will tell what kind of audio software your laptop is using. You may click hardware and click the sound software and the driver update or roll back drive will appear choose which one you preffered. if this did not work just download driver.You can go download to the web site a driver. click control panel click add and remove you can see the the kind of sound software your laptop is using. You can use a different sound driver for your laptop. Realtek 97. type www.realtek.com and free download sound driver.Before installing the a new drive you have to delete the old sound driver to your laptop to the control panel. then install the new driver. Hope this will solve your laptop sound problem. You may contact us again, if run in to a problem we will be glad to help you.
Aug 15, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
My speakers won't work. It says, "no audio devices are intalled. when I go to my device driver, it says it's working properly.
Go in the control panel and click on the sound icon and make sure that your sound card is the default sound device.
Aug 06, 2009 | Toshiba Satellite L305-S5907 Laptop
No sound
try to check the speakers or microphone lines and jacks whether they are connected properly . if still does not work, then check the audio settings under sound and devices in control panel.
If still makes no difference , then try reinstalling the audio drivers via the CD that was provided to you or u can find the drivers on http://www.toshiba.com or http://www.driverfiles.net/Notebooks/Toshiba/Tecra-9100/download/page,sh,31396,221,19,.html
May 25, 2009 | Toshiba 80GB Laptop for Satellite 2400, A,...
L have a toshiba satellite m55-s331. I have very low volume. Tried the obvious inc downloading new drivers, updating ect. Nothing works! I have realtekAC97 audio driver. Please help! Keep it simple as I am...
You might be able to adjust the volume further from the control panel.
In windows xp click "start" and then select "control panel" Next click sounds, speach, & audio devices next to a speaker icon. Then click the "sounds and audio devices"
you should be able to adjust the volume there as well as a volume control on the front or side of your laptop.
good luck
Jan 30, 2009 | Toshiba Satellite M55-S331 Notebook
No sound and audio after reformating my computer
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in ww.google.com
Sep 11, 2008 | Toshiba Satellite A135-S4527 Notebook
Sm bus controller drivers
reinstall sound device drivers. go to control panel/right click properties, locate sound/audio and see if all drivers are working properly.
Jun 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite 1905
First, try pluging in an exteral mic to check the mic itself is not broke. Next Go to the device manager to check for driver problems (control panel, system, Hardware look for yellow ?'s) Check control panel, Sounds and Audio, audio, sound recording, volume. There are just too many ways to mess with the sound settings, and they often seem to just mute themselves!
Good luck
Mar 17, 2008 | Toshiba Satellite R10-S802TD Tablet PC
No sound on the laptop
If you have windows XP check : control panel / Sound speech and audio devices / Sound and audio devices. Then check that the volume cursor can be moved and that the device is not muted. If this doesnt work remove the sound card from device manager, and install it back using drivers from your recovery disk or download them from Toshiba website.
Hope it helps
Feb 14, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
