Question about Roper RAS6233KQ Top Load Washer
Washer stops half way through rinse
I have a Roper RAS6233KQ Top Load Washer. Before i put two pillows in the washer it was working fine. The tub if full of water. If the dial is turn to re start the rinse cycle it starts then when it is half way done it stops.
  • Anonymous Jan 27, 2008
    I didn't wash pillows, I washed a comforter. But the rest of this post could have been written by me! That's EXACTLY what my problem is! Now what? (I've restarted the washer in the rinse cycle several times; it agitates and runs for a bit and then shuts itself off at the same point every time.)
Did you check the lid switch?
Posted on Feb 18, 2008
My Roper top load washer stops in mid cycle and will not drain or do anything else
Most of the time that is lid switch failure. The lid switch must be engaged before the tub can spin. You can bypass the lidswitch to see if that is the problem. The lidswitch has 3 wires. 2 live wires and one ground wire which is green and bolted to the frame. Tie the 2 live wires together and see if the washer will work. You can use it that way but is could cause harm if anyone was to try and grab clothes out the tub while it is spinning full blast.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 23, 2012 | Roper RAS6233KQ Top Load Washer
I had troubles with my washer going through a cycle and stopping when it got to the rinse cycle. I put in a new timer, the machine worked great through part of a cycle but again quit just at the rinse...
Verify that BOTH hoses are hooked up to the correct water inlet and they are TURNED ON and FLOWING. Your condition acts like hoses are reversed, and the hot (cold actually) is turned off, that will cause the machine to stop on the rinse cycle....
Mar 04, 2011 | Roper RAS6233KQ Top Load Washer
My machine stops working after the rinse cycle and won't go into the spin cycle. The water stays in the tub and will not drain. I have unplugged and replugged the machine just to make sure. I wanted to see...
It sounds like the Drain pump may have stopped working. After the rinse cycle, the machine should drain the water and start spinning. The Drain Pump should be at the bottom of the machine.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 22, 2011 | Roper RAS6233KQ Top Load Washer
The washing machine will fill and agitate but then stops...will not continue and water will not drain. When putting it on spin, rinse, anything, it just agitates then stops.
I think u need to open lid when in this condition put pencil in longgated hole if machine starts u need lid switch or acturater haundi24
Sep 29, 2009 | Roper RAS6233KQ Top Load Washer
My Roper RAS6233KQ washer wont drain or spin.
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have questions, please let me know. I hope this helps you.
Aug 03, 2009 | Roper RAS6233KQ Top Load Washer
Roper washer ras6233kq
Hello, So unit should fill with water though right? Just no spin and drain. more than likly you have a bad lid switch. look and see if there is a hole somewhere on the frame. usually on the lid you will see a actuator that plunges into the lid switch. When you close the lid you should hear a click if there is no click you a bad lid switch.
Dec 24, 2008 | Roper RAS6233KQ Top Load Washer
check the lid switch on the washer loosen the two screws on the control panel end caps pull the control panel slightly forward and tilt on its hinges then you will see a connector under the panel it has three wires one is gray one is green i think the other is tan unplug the connector and put a jumper wire from gray to tan to by pass the switch lower the control pane and start the washer to see if it continues if it does replace the lid switch
May 24, 2008 | Roper RAB2121KW Top Load Washer
Stops in middle of rinsing
We haven't heard back on this in a week. I'm presuming the unit is now working?
May 24, 2008 | Roper RAS6233KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
222 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
