Question about Intertherm P3RA-048K Air Conditioner
Low heat when heat comes on blowe works fine but dosent have much warmth .
    Problem Solver:
  • 25 Answers
If this is a heat pump it should either be low on freon or problem with airflow over outdoorcoil. (like a fan that failed or really dirty coil) PLEASE keep in mind if this is your first year with a heatpump instead of a furnace it does blow air out MUCH colder than a gas furnace or boiler.
Thanks ,
Brian
Posted on Nov 24, 2008
Bionaire heater sometimes turns on at very low intensity and just kind of chugs along as the yellow button flashes. It works fine just wondering why it does that
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Jan 30, 2016 | Bionaire Heating & Cooling
NO HEAT. A/C works fine. Air blows but no warmth. blows cold air for front defog and cold air blows when temp cranked high 1-5
warmth comes from the heater in the car
if it is climate control check the climate control module
check for heater control in the vent settings as the hot water tap may not be turning on
Sep 20, 2015 | Pontiac Grand Prix Cars & Trucks
Nissan altima heating problem
the ac and heat are two seperate units, the heater hoses are coming from the heater may be loose or cracked check your fuses and relay switches
Jan 07, 2014 | Cars & Trucks
2003 ford taurus blows lukewarm when the heat is on. Blower blows fine and a/c works great.
Check out the heater hoses for warmth. Both should be the same with the water flowing. If they are not, the water is not circulating.
There are 2 ways the heater can work. One style varies the amount of water flow to control the heat levels. The other uses the blend flaps in the ducts to push air flow around the heater core.
If the heater hoses are not circulating water, a part called a flow valve is to blame. Check out the autoparts sites for photos of the flow valve for your car. If you have the blend flap system, a solenoid called a "motor" is not changing the position of the blend flap in the dashes' ductwork.
Oct 01, 2012 | 2003 Ford Taurus
Espree 1967 water gets warm but not hot. thermostat and heating element ok
try setting your thearmostat to 0 and then the desired warmth. sumtimes the calebrations go out over time, if that dosent work let me know. im a plumber so i know this stuff
Jul 04, 2010 | Jacuzzi Home
'96 buick regal- heater not producing warmth. fan blows fine and i did check passenger temp contol(set all the way warm) with no results. next best check???
Check the temp of the heater hoses going into the heater from the engine in the engine compartment.
If you have a temp gauge on the dash does it go at least 1/3 the way up the gauge from cold in normal driving.
You can take a garden hose and flush the heater....both ways back and forth then reconnect heater hoses and check for heat.
But.....The # 1 cause of no or low heat is the engine thermostat.
It needs to close tightly to force the engine coolant through the small heater core.
Nov 10, 2009 | 1996 Buick Regal Olympic Gold
No Cold air from 99 Montero Sport
replaced clutch, driver ac belts on 2000 montero sport a/c is still not blowing cold any ideas
Jun 30, 2009 | 1999 Mitsubishi Montero Sport
A/c cooling fine but not heating
The fan generally does not come on until the unit has achieved some high head pressure so that it can produce hot air. If it is low on gas it will not get to this stage.
Jun 26, 2009 | Heating & Cooling
Heater blows cold air from top vents after running for 1.3 hours
Sounds like you may be able to fix it by flushing your antifreeze and back flushing the heater core. Some car owners cheep out and put stop leak into the antifreeze, others dont change there antifreeze at all. Both are mistakes.
Mar 05, 2009 | 1990 Chevrolet Lumina
Intertherm P3RA-048K Air Conditioner Logo
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
