Question about GE Spectra JGBP30 Gas Kitchen Range
Ours is a xl44 spectra oven will not ignite, broiler sometimes.
The oven will not ignite. the broiler sometimes ignites. this appliance is only 4 yrs old!!
  • GE Master
  • 5,569 Answers
Don't you regret now to have shoved your old range out the door? Sorry, it just seems that each time we replace something we end up regretting it.
Your problem is appparently not uncommon and while the model numbers differ, I think you will find the solution in the discussion lined below:
Oven-Broiler ignition problems
Posted on Dec 29, 2008
SOURCE:
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
XL44 oven will not work
The fact that the igniter on the broiler actually begins to glow rules out your Electronic Oven Control (EOC) board. Usually when both oven features fail to work the EOC, or wiring, is the culprit. But...in your situation, the broiler igniter glows, but the bake igniter doesn't. You don't see this happen very often, but I believe you may have two bad igniters. The following link explains how to replace an igniter and gives you some theory behind how they operate:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Although an igniter glows, it still may be bad. This is usually dependent upon the age of the stove and the frequency of use. Usually, the bake igniter burns out first, because it is used more often. These igniters also grow weak with age. Which means, if they do not draw the required current necessary to open the gas safety valve, you will not have ignition. This is a designed safety feature that prevents free flowing gas from filling the oven box before ignition. I would recommend replacing both igniters to see if this corrects your problem. If you require additional assistance, or have questions, please let me know before you rate the solution. I hope this helps solve your problem.
Feb 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
XL44 Gas Range will not light
Kinda sounds like the hot surface igniter is out. It is located under the oven section under the bottom panel. They are relatively easy to replace except you need that oven today I'm sure. Let me know how it turned out.
To replace the hot surface you need to take the bottom panel off and access the assy you need a 1/4 nut runner and remove couple small screws unplug the igniter take it to a parts house and 12 to 20 dollars later you're good as gold. When I say parts house appliance parts.
Nov 27, 2008 | GE Ovens
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
GE Profile Spectra XL44 oven wouldn't light, stove top and broiler works
We have our second GE stove and it has started to do the same as the rest of you.  Our first stove began to suffer igniter issues after 4 or 5 years.  I called GE and was given a simple test procedure for the igniter using a multimeter that I don't remember and likely wouldn't post regardless lest someone do things incorrectly... In any event, as I understand, the gas flow is tied to the igniter temp.  As the igniter ages, the temp that it can achieve gets lower. Eventually, it hits a point where the temperature isn't sufficient to reliably ignite the gas and our problems start.  The solution is fairly simple.  Replace the igniter. So, call a repair person and tell them the problem.  They can come out and instal the new igniter.  Unless you are a licensed or certified repair person, DO NOT DO THIS YOURSELF.  Let the pros handle repair to gas appliances.
Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
See all GE Spectra JGBP30 Gas Kitchen Range Questions
GE Spectra JGBP30 Gas Kitchen Range Logo
418 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
