Question about Lexmark X1240 All-In-One InkJet Printer
Printer wont print, but it is going through the motions.
Lexmark x1240 Printer is making all of the noises, paper is going through printer, but pages come out blank. Ink levels are fine.Please help.
  • Anonymous Nov 30, 2008
    I'm having the same problem with the color ink. My printer is printing black just fine but when I try to print color all I get is blank page.
    I tried cleaning the heads using the maintenance option but it hasn't helped.
  • 162 Answers
If ink cartridges are new, perform print head or maintenance cleaning at least 3x consecutively.
Posted on Nov 24, 2008
Wont print
It could be that your cartridges needs some cleaning. Try to follow the steps below to fix the problem:
  1. Make sure your printer is connected to your computer and is turned on.
  2. From your computer, go to Start menu.
  3. Go to Programs or All Programs.
  4. Go to Lexmark 1200 Series folder.
  5. Select Lexmark Solution Center.
  6. From the Maintenance tab, select Clean to fix horizontal streaks.
Your printer will then print a test page forcing ink through the cartridge nozzles and clean them from possible clogs and dirt. After successfully printing the page, try to print your document again to verify that the problem is fixed.
If that doesn't help, you can manually wipe the cartridge nozzles with a slightly damped paper towel. Then reinsert the cartridges and try to print again.
If the problem continues, then it could be a faulty cartridge. Try to insert a different known working cartridge or better yet a brand new genuine Lexmark cartridge. Lexmark products work best with original supplies.
I hope this helps. Thanks.
Nov 19, 2011 | Lexmark X1240 All-In-One InkJet Printer
Ink cartridges are full. paper moving. Not printing. no ink on papaer.
printer in ready, but lexmark all in one center's main page did not icon and i can not printer or change color
Apr 17, 2010 | Lexmark X1240 All-In-One InkJet Printer
X5470 lexmark has paper jam now makes squealing noise when I use it!
Try this. Remove any paper jams, take out all sheets of paper and remove all cartridges from the printer. Close the cover. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer's ready, re-insert the cartridges. The printer will print an alignment page. Load just 5 sheets of paper only. Let it print the alignment page all the way through without cancelling it. If printer is not making the squealing noise, problem resolved. If it's still making the noise, the printer's mechanism somehow got affected by the paper jam now. If that's the case, any mechanical/hardware problem in the printer, it's better to ask assistance from Lexmark. If printer is damaged already, and it's still within warranty, they might send you one for replacement. Good luck!
Apr 07, 2010 | Lexmark X6170 All-In-One InkJet Printer
My ink cartridges are reading almost full and it says printing started and goes through the motions of printing my page...altho the page turns out blank. What do i do?
Get a swab and try cleaning the copper contacts at the base of the ink carriage. Then clean the base of the ink itself. Even a full cartridge can dry out around the nozzles if you go too long between print jobs.
Nov 02, 2009 | Lexmark X1240 All-In-One InkJet Printer
Color cartridge do not want to print
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 28, 2009 | Lexmark X1240 All-In-One InkJet Printer
Printer doesn't print even with new ink cartridges.
turn the printer i turned on and Press the cleaning button ,. Cleaning takes about two minutes, the printer makes some noise when it finishes you run a nozzle check for print quality and reset the cleaning cycle.
load paper . go to the printer menu as follows: click Control Panel, and then double-click Printers. Select the Epson printer if have more than one printer is installed. Click File, click Properties, click the Utility tab, then click the Nozzle Check icon.
The printer will print a Nozzle Check pattern in black, and in cyan, magenta, and yellow. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If any dots are missing, clean the head again.
If your software is different, and does not have these options, you can do it this way:
1. Same as above.
2. Same as above.
Turn off printer and computer. Disconnect interface cable from printer. Load paper. Hold down the load/eject button and press the power button to turn on the printer. Release both buttons.
3 Same as above.
4 Turn off printer and reconnect the interface
May 17, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark x1240 printer will not print.
Keep your paper feed under 15 pages. The paper will tend to pull to the right, but it will print correctly on the printed page. 20 to 25 pages in the feeder will result in a paper jam. To find the status on the print job, go to your control conter and hit printers. Choose your spicific printer and you may beable to save the printjob.
Apr 16, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark x1240 will not print
did you tried to set the properties to mono ?
Apr 12, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
280 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
