Question about Maytag Neptune MAH5500B Front Load Washer
Water in drum
When i turn the drum its seems water in in drum
  • aims831 Dec 07, 2008
    So does that mean its going to smell like musty water forever?
  • MrSandoval Dec 11, 2008
    the spin cycle doesn't completely drain the water, leaving my clothes sopping wet.
    President:
  • Maytag Master
  • 2,651 Answers
Thats normal forthins machine they actuall use a water filled front ring for balance, woll always sounds as water is there. desgined that way
Posted on Nov 25, 2008
Lat2500aae We have a Maytag Performa, Model
it sounds like the shocks on the drum maybe failing. on this model the washing machine mother board is close to the outer drum. the out drum may have made contact with it. and not turning on the pump to let the water out.
Oct 06, 2013 | Washing Machines
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
Drum does not turn
Looks like micro controller problem.
Apr 05, 2010 | Asko W6221 Front Load Washer
The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Jul 28, 2009 | Washing Machines
Washing machine drum won't turn when loaded
your gers in the cluch sistem are gon for good ,,sorry
Apr 05, 2009 | Fisher and Paykel (IWL12)
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Crunching and grinding
That noise come from the pump that drived the water out the drum. Since you don't have this noise every time, it's seems like it's cause an unclean filter issue. Cleaning the filter - should solve this issue. Before openning the filter, prepare a bowl and a floor cloth to avoid water's flooding. Good luck !
May 24, 2006 | Hotpoint First Edition FEW12 Front Load...
Maytag Neptune MAH5500B Front Load Washer Logo
401 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
