Question about Compaq Presario 700 470024-192 Notebook
Compaq doesnt power up at all
I got a friends Compaq Presario 700 to repair. she did not use it for the past two months and all of a sudden we tried to power it up and nothing. power source seems to work (light is on and power tested) i tried to unplug it without the battery and pressing power button for 30 sec but no luck still does not turn on...?
  • 6 more comments
  • sxristi Nov 24, 2008
    well thank you for your response however i did take the mem out tried power start and still nothing. when you mean clean the memory you mean blow dust etc off it right? i did that and put the chip back on still no power. it is strange. i did take the pc apart and took the little round battery out to check if it is ok and it read 2.7 volts so the little battery is working too. all power source seems to be fine so i dont know what else to do now?
    it is a compaq presario 700 laptop.
    yes i tried removing the battery too. still nothing.
    i applied pressure to the pin with a small flat screwdriver and it seems very stable..
    i took out the flat battery inside the laptop and its voltage is 2.7 so it works i think fine.
    i also tested the power supply at 19 some volts
    so now i read something about testing the battery because some units dont work on a dead battery. i am not sure how to get the battery tested because it has a grid of terminals so which is + or -? anyhow keep up the feedback. thanks
    thanks :|
  • sxristi Dec 02, 2008
    finally after leaving the laptop plugged in for several days the battery was charged and it did start up. Thank you all for your advice.
  • sxristi Dec 03, 2008
    well it is me again. and i need to report for informative purposes that after a format and new copy of windows and drivers the compaq is back to not responding status...so i guess that maybe the battery is not the problem that i had assumed. :(
  • sxristi Dec 05, 2008
    Several days have gone by and I have noticed the following...When I leave the pc plugged in the power supply with or without the battery for several hours (6-7 hrs) the power light comes on and I can start the pc. I can do numerous restarts and leave on the pc. However if at any time i shut down the pc then it will not restart and the charging light will not be on. At which point i will have to leave it on again for 6-7 hours for the light to come back on so i can start up the pc again...What do you thing the problem is? Internal 2.7V battery mayb? or something else?
  • Compaq Master
  • 4,806 Answers
Try removing the memory and clean it, if you have more that 1 put hem back 1 at a time turning the laptop on each time
keep us informed
regards
Posted on Nov 24, 2008
  • 2 more comments
  • Lee Hodgson
    Lee Hodgson Nov 24, 2008
    is this a desktop or laptop?
  • Lee Hodgson
    have you removed the laptops battery (not the one on the motherboard) and tried it on AC power only?
  • Lee Hodgson
    ok, now look at the AC adapter on the laptop to make sure that the pin is not loose or broken inside
  • Lee Hodgson
    + is the top of the battery - is bottom (where the grid is) you could try a new memory module in place of the existing one to make sure its not the memory that has gone faulty. Appart from that you have done just about everything you can do at this moment in time, if a new memory module does not start the machine then chances are the motherboard has failed
    regards
I got this Presario 700 from a friend. it has a
Compaq Presario 700 Memory
Maximum Memory 384MB
Memory Slots 1 (1 bank of 1)
non-removable base memory 128MB
Machine name: Compaq Presario 700
CPU options: AMD Mobile Duron (900MHz)
Chipset: VIA ProSavage KN133
HD Bus: Ultra ATA-66
Front Side Bus options:
Memory Speed options: PC133 144pin SDRAM SODIMM
Hope this helps you out. Have a Happy and safe 4th of July weekend!
Jul 02, 2010 | Compaq Presario 700 470024-192 Notebook
Audio device out of update
hi sir
i need to compaq presario c700 audio drivers
Dec 19, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq presario c700 sound drivers
i have compaq presarioc700 and i have installed window xp os and i cannot able to install sound driver plz suggeset me
Aug 27, 2008 | Compaq Presario 700 470024-192 Notebook
Needs sound drivers for compaq persario C785TU
Go to www.HP.com and click on Drivers and Downloads.
HP and Compaq are one in the same.
Aug 07, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 PC drivers i want
i have compaq presario 700 and the audio sound is not working please help me to fix this problem
Problem with Lan driver for F739AU (PLEASE HELP ME)
You can find it here
http://www.zyxware.com/articles/2007/12/01/drivers/compaq-presario-c707tu-laptop-drivers
Jun 13, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq presario powers on but dont boot
RE INSTALL YOUR OS (LINUX OR WINDOWS OR VISTA ETC)
Nov 24, 2007 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
79 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
