Question about Dell Latitude D600 Notebook
Thanks for your initial efforts , ref dell latitude d600 laptop.
I checked my RAM using the windows help centre , it informed me that my laptop has 512MB of RAM.
Then i pressed F2 to enter the seires setup and there it said my System memory was 464MB at 266MHz.
If it helps the exact message it says when i turn my laptop on is;
memory write/read failure at 1FFE000C read FF91FE11 expecting FE11FE11.
memory address line failure at 1FFE0000 read FE11FE11 expecting 01010101.
memory write/read failure at 1D00001C read 01EF00EF expecting 00EF00EF.
Decreasing available memory.
The amount of system memory has changed.
Strike the F1 key to continue , F2 to run the setup utility.
....oh , I checked the time/date in the setup utility and it was already correct.
Does any of this make sense to you ?
Really appreciate your time and help.
MICHAEL..
  • Anonymous Jan 28, 2009
    Sergeant:
  • 177 Answers
Well there is certainly a RAM related problem. You have to open your RAM Module, Clean its golden coloured edges and reinsert it properly. Then start your laptop to see if it changes anything. If everything remains same then you have to replace your RAM.
Be very carefull if you open your RAM. Consult your Manual first.
Posted on Nov 24, 2008
Dell latitude d820 wont fit tv sreen when duel monitors are set
Looking for Dell service Centre in chennai?get in touch with the laptop shoppe the best dell laptop service centre in chennai,the one stop solution centre for all your laptop queries and we ensure your laptop is repaired and it can smoothly within minimum downtime.
Nov 22, 2012 | Dell Latitude D600 Notebook
D600 wont power up
Try removing the battery and boot on the power cord sometimes the battery shorts the system so it will not boot if it does boot then you need to replace the battery it could be the battery is dead and your power cord is bad check and make sure that is not the case if the power cord is good then I would look into replacing the mother board you can find a replacement on Ebay or at dell .if you have to replace it do a google search on hot to replace the mother board on a Dell latitude D600
and you will ba able to get step by step on how to disassemble it
Aug 28, 2011 | Dell Latitude D600 Notebook
Just bought a new 120G HD for my Dell Latitude D600. The following error message comes up every time I turn it on: MEMORY ADDRESS LINE FAILURE AT 28000000 READ 00000000 EXPECTING FFFFFFFF DECREASING...
While the "memory loss" won't cause a major problem, you will be annoyed by the repeated message. A couple of things may be causing this. One, Windows changed the virtual memory size. This is an area on your hard drive that the computer uses to store stuff when the on board ram isn't large enough to handel it. the other thing that may be happening is you have a memory module going bad. You must remember that the hard drive size has nothing to do with the memory size. That is, your ram memory is what handles most of the processing of information. Your hard drive is just a storage place. Like a file cabinet in your office.
If this information was helpful, please rate it high. Thanks
May 24, 2011 | Dell Latitude D600 Notebook
I want to download drivers for my latitude d600 what should i do?
Hi, best place is the dell website, use this link: http://www1.euro.dell.com/uk/en/business/Laptops/latitude/ct.aspx?refid=latit&s=bsd&cs=ukbsdt1&ref=lthp&ST=dell%20latitude%20d600%20pc&dgc=ST&cid=41142&lid=1069631&acd=1238399295205648
You need services and support, follow the instructions, its all you need.
Jul 10, 2010 | Dell Latitude D600 Notebook
Dell latitude d600 wont turn on
test power supply- test ram- have cpu tested- test connection from front button to motherboard
Aug 06, 2009 | Dell Latitude D600 Notebook
My laptop has a mind of it's own!
check for viruses
do a win update
and add remove uninstall any programs you no longer use
do a disk cleanup then a defrag
Jan 28, 2009 | Dell Latitude D600 Notebook
Dell latituded600 charger lcd off,
Ok... that makes a little more sense... Here is what i want you to check... Disconnect the AC Adapter from the system and plug it into the mains, check the LED light (Should be Green). Then plug in the connector to the laptop, check the LED. If the LED turns off when you connect the laptop. Your Laptop motherboard needs to be changed.
Jan 14, 2009 | Dell Latitude D600 Notebook
Wanted: replacement display screen - Samsung 14.1"
HI
You can buy from any of these.
http://www.google.com/search?rlz=1C1GGLD_enIN307&aq=f&sourceid=chrome&ie=UTF-8&q=D1002+dell
I have got almost 3.
Shopping results for D1002 dell D1002 - Dell Latitude D600 LCD Screen $149.97 - Renwerx Tech DELL D1002 LATITUDE D600 SXGA+ 14.1 DIS $253.75 - codemicro.com Dell D1002 LCD 14.1" TFT SXGA+ LATITUDE D600 $488.75 - eBay
Do let me know if you need further information. Its pleasure to assist you. And let me also inform you that can call Dell Spare Parts Sales and ask them to get this one for you. You get 90 days of warranty as well.
The part number is D1002 for the monitor.
Thank you
Rakesh
Dell Expert
Jan 06, 2009 | Dell Latitude D600 Notebook
Can not start normaly and can not start in safe mode
On your Latitude D600, press and hold the <Fn> key while powering the system on. This will initiate a diagnostic routine to check your hardware. If no errors are detected, then you have a problem with your operating system software boot files. For more info go to this Microsoft website:
http://simple-pc-help.com/support/errors_0x00000024.html?t202id=7396&t202kw=0x00000024&gclid=CKasgPmAzZYCFQa6sgodtiQIxg
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 29, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
629 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
