Question about Carrier 38BRC048 Air Conditioner
Cleaning the filter
I have a Carrier central air gas furnace.  Before turning on the heat this year, I need to clean the filter.  The furnace has the type of filter that you clean instead of change.  I can't remember how to get the filter out so I can hose it down.  Can you tell me how to open the furnace and take out the filter?
    Problem Solver:
  • 25 Answers
The two doors are removable. remove top one that has all the small openings where you see the flames at. This is done be grabbing handle and lifting bottom part can be pulled towards you.than bottom one can be lifted up also. be carefull sometimes the edges are extremly sharp and can cut to the bone. (i know from experiance.) I belive a disposable filter is a much better way to go. only get the cheap spun polyester ones not the high filtration ones.
Posted on Nov 24, 2008
What year was Amanda air command high efficiency 80 gas furnace produced. Have problems with dust. Notice furniture gets dusty when furnace on.
The year it was produced has no relevancy on tyhe dust in your home. You may want to consider having your ducts cleaned and possibly a pull and clean on your blower wheel. Also a good cleaning on the evaporator with routine filter changes will help with dust as well. Best Wishes.
Aug 21, 2017 | Heating & Cooling
I have a coleman furnace model 4066A656
Make sure your air filter is clean. Is the thermostat satisfied? or is the room temp. still below the thermostat setting? When ever you have to turn the power off and then back on to a furnace that usually indicates that the furnaces ignition control locked out. The first thing that I would try is cleaning the flame rod.
Mar 02, 2017 | Coleman Heating & Cooling
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Bryant furnace
Check gas valve is not on pilot only check air filter is clean check connections to gas valve .
Oct 10, 2017 | Heating & Cooling
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
Extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Cleaning electronic air filter
What brand and model is the air cleaner?
Often you can find the mfg. website and download the .pdf file of the manuals.
The air cleaner will be located on the return air duct of the furnace and should have a nameplate and a model# somewhere.
Some use disposable filters and some need to be cleaned with dish detergent and can be very fragile. Hope this helps.
Matt
Jan 04, 2009 | Carrier 38CKC036 Air Conditioner
Problem with furnace, air but no heat
the hot serface igniter may nead to be replaced again . if the is a lack of air
[ have this checked} getting to and frome the furnace it may be causing the furnace to cycle off the burner duing call for heat. it recycles back on and off untill the thermostat is saticfied. this means you are reusing the igniter more often the once a call for heat . therefore shorening it life expectancy.. make shure you are not blocking the air flows with over filtering ..whitch i have found to be the most common mistake . this and not changing or cleaning air filters often enough.
Oct 20, 2008 | Bryant 462AJC021BA Air Conditioner
Central air conditoner unit doesnt blow cool air into home has some ice on the inlet heat and cooling lines going into the central air unit
Change the furnace filter. Make sure you use a cheap one when air conditioning, as the better ones restrict airflow when they filter out so much stuff and then plug up, not allowing enough air to pass over the cooling coil in the furnace's air plenum. Turn the A/C off for a few hours (with only the furnace fan on if possible) to melt the ice off the cooling unit inside the furnace.
Sep 01, 2008 | Carrier Heating & Cooling
Carrier 38BRC048 Air Conditioner Logo
126 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
