The tiller starts and runs but backfires at times and loses power and shuts down. I took off the fuel tank, put clean fuel in it, put air thru the lines, checked the air filter, the fuel filter, it runs rough and the one screw to adjust it - seems to make no difference....the governor seems to be on and spastic moving all the time...and then it shuts off. I don't know what to try next - I changed the oil hoping that might help...it didn't.
SOURCE: ihave a craftsman 5hp(briggs&stratton) reartine tiller that won't
Hi.....I am assuming that you have a bowl type carberator on that tiller. If so, the bolt on the bottom of the bowl, is the main jet. If you remove it, you SHOULD, see a hole drilled from the top down to a hole cross drilled thru, near the bottom. Run a small wire thru these to be sure they are clean. Other then this, I'd install a new needle and seat. You can purchase just a needle and seat set, no need for a complete rebuile kit. You will also need a bowl gasket, and if you have a primer bulb, you will also need a new intake gasket or the primer will not work worth a darn. Hope this is of some help, good luck
SOURCE: need to know how to time honda harmony tiller
well
heres your 4 strokes
1 intake down
2 compress up
3 power stroke down
4 exhaust up
if you start with you start with the piston just a couple of degrees past TDC (top dead center) so that it has started its return down
now set the valves so they are closed:
if you have an adjustable valve clearance's then your clearances should be noticeable like 10 thousands ( you should be able to move the lifter ( rocker arm ) and it will be loose up and down
with the spark plug still out; so you can see the piston coming to TDC and passing it to come down
turn the flywheel and watch the strokes and the condition of the valves
1 just past tdc, the intake valve opens and the piston goes down for the intake stroke
2. jst as the piston comes around BDC the intake valve should close and return to tdc with all valves closed ( the compression stroke )
3 just past TDC the ignition will fire and the piston will return down with both valves closed( the power stroke)
4 just past BDC the exhaust valve opend , the piston travels up and completes the exgaust stroke.
and after completing the exhause stroke and arriving at tdc the intake valve opens and you start over again 1,2,3,4
