FixYa.com
Tags:
Logitech Z-5500 Computer Speakers
Logitech Z-5500 Speaker stand problem (by 2 users)
posted by Sneezy D on Dec 31, 2006
I recently bought speaker stands for my Logitech system. Before realizing that the setup would not require me to remove the speaker's desktop stand, I removed it. I unscrewed the screw holding it in, and the stand came off, with the screw and two washers. Something sounded like it came off and fell inside the speaker, and after a little bit of shaking to try and get it to fall out, the sound stopped. (Now it sounds like there's nothing jiggling around in there.)
Now, I can't put the desktop stand back on. Am I missing something? THe screw won't screw in. I'm afraid to test another speaker, for fear of putting it in the same condition.
Any help would be MUCH appreciated, thanks!!
Stu
Philly
sneezyd@comcast.net
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 13, 2008
How exactley does the satelite dissasemble. i removed the 2 screws holding the speaker wire inputs, but i can't get the back to pop off.
Best Solution
posted on Jun 19, 2008
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had the same problem, just remove the grill in front of speaker to expose the holes at the 4 corners of the speaker with rubber plugs.
take out the rubber plugs, underneath there are screws.
take the screws out and you can dismentle the speaker, do it slowly and gently so as to avoid snapping any wires, and there lies your nut somewhere.
with the speaker dismantled still, reattach the stand and then reassamble the speaker.
-Fixed, Technobbs
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 13, 2007
FixYa! (100)
Paul Driver
Rank:Master Master
Rating: 85%, 42 votes
The stand was held on with a nut on the inside.
There is not longer a nut on the inside of the hole, so there is now nothing for the stand screw to attach to.
The nut is now stuck to the magnet on the speaker.
You will need to disassemble the speaker housing to remove the nut from the speaker magnet and reattach then stand.
peace.
Paul.
Solution #3
posted on Oct 22, 2007
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
remove the rubber things where the removable cover attaches to and unscrew the inside screws
Solution #4
posted on Feb 10, 2007
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
I don't think you have to worry about the speaker. If the nut is attached to the speaker magnet, nothing will happen to the speaker.
Solution #5
posted on Apr 21, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Always read the instruction manual before pulling apart your speakers - logitech clearly state in the instructions NOT to remove the screw as the retaining nut inside the speaker will be come detached - unscrew in haste then repent in leisure
Can you Help with these Computer Speakers problems?
Computer Speakers
Logitech Subwoofer X540 PC...
Hello, Does anyone have any... Answer This...
Computer Speakers
Can't get my durabrand uc-280...
Can't get my durabrand uc-280... Answer This...
surround sound help
i cant get surround to work ony... Answer This...
z 5500 only 2 channels
i cant seem to get al 5... Answer This...
I have the Logitech Z5500
one of the speakers the screw... Answer This...
Repair Service
Find Computer Speaker Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
