I have an Archos 5 (250gb version) and am having tremendous problems connecting it to the TV/Sky Plus box via the dock and wonder if someone can help? Also, it will not connect to my home wifi set up (BT Home Hub) yet other items connect without any issues at all. Any advice greatfully received!
Go onto the archos website and find the product and watch the tutorials on how to do these thing if you have tried that already then i don't know what is wrong
Posted on Jan 19, 2009
How to besto connect this unit to record from Sky plus box
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
Oct 26, 2013 | Panasonic DMR-E65 DVD Recorder
How to set up Archos DVR Station but unsure how
Hi awillis98 this is Mike Houston of DISH Network, with the Archos DVRstation there will be a USB connection from the device to the DISH Networkreceiver, one the DISH receiver has recognized the external hard drive you willsee pop-ups on the screen that will walk you through the steps to configureyour Archos device. I will send a link to help with the setup for the externalhard drive. http://www.dishnetwork.com/SupportSection/setup-ehd
Apr 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Archos 605 160gb keeps switching off
I save all my data to an external hard drive, restored factory settings and then transfered my data back to the Archos. It seems to be working OK now.
Before anyone else tries this they need to make sure that they have the access codes for any plud ins that they've purchased.
Apr 05, 2009 | Archos TV Plus, 80GB 80 GB Hard Drive
Can I pre record on the archos 605 wi fi 30gb
You have posed a very good question with a very complicated answer. There are two things you MUST have in order to do what you are asking:
1) Your "docking station" cannot be the Archos mini-dock, b/c the mini dock has inputs only. Your docking station must be the Archos DVR Station - Gen 5.
2) You have to have a digital cable box, FIOS, or digital satellite box.
You will be recording from your cable, satellite, or FIOS box instead of directly from your TV. Hook the red, white, and yellow cable from one of the red, white and yellow outputs of your cable/sat/FIOS box to the specialized adapter of the DVR Station (make sure your Archos 605 is properly docked inside). Here is a link to the connection guide if you don't have it:
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
Once the connection is set up, you must follow the exact directions printed on pp.11-15 of the DVR Station user manual - it will require downloading several pieces of software. My only reccomendation is that you make sure that the Archos 605 is fully charged before proceeding, b/c if it loses power during the process, you may ruin your mp3 player. Here is a link to the DVR Station user manual:
http://www.archos.com/support/download/manuals/english_user_manual_dvr_station_gen5_v3.pdf
If you have followed the instructions exactly, you will be able to schedule your recordings to your Archos 605.
There are two catches that I noticed with this player - 1 major and one not-so major:
1) Not-so major: Your subscription to the TV guide that enables you to schedule recordings will only be free for 1 year
2) Major: The DVR Station forces you to choose between an NTSC and a PAL format when choosing a TV standard for playback. PAL is only for Europe, so never select it under any circumstances. NTSC is shutting down on February 17, 2009 - in a little more than a month. After that time, you may not be able to display the recordings that you have made to your TV itself.
-Tha Mp3 Doctor
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
Dvr docking station
I had the problem that the record feature was not available in or out of the docking station and therefore i could not record. Archos connector on bottom of unit senses a change in the resistance of the device it's docked with and knows if it's the DVR station or not.
Turned out to be a hardware fault - i had to RMA both the Archos and the docking station (while in warranty) and Archos fixed it/them.
That may not help you much.
PS: I think i zapped my DVR station with static one day and that might have been the original cause.
Dec 31, 2008 | Archos 604 WiFi Digital Media Player
Connecting the LE46A556P LCD TV to the HTZ310R Home Cinema System
You need to be connecting the TV and the Sky Plus to the HT box via optical (toslink) for full surround sound. As you only have one optical port on the HT, I would suggest buying a Optical selector such as this one. I would also suggest looking on avforums more more help. I use it for most of my questions if ever i need any help.
Hope this helps!
May 22, 2008 | Televison & Video
I have an Archos 605 WiFi. I haven't yet connected my Archos docking station to the TV and HDD. Meanwhile, I thought I would copy a programme from the HDD to a DVD, then put the DVD in the computer and...
What kind of HDD do you have, do you have any type of output on it. You stated that you haven't connected the docking station to it and the TV...? The best thing to do is to connect your Archos to the Docking station. Set the docking station up correctly, with cables coming out of the HDD (if it has some sort of output) to the station and out of the station to your TV. Once you set that up, you can use the Archos as a mini DVR or VCR. Go to the REC option on the main screen of Archos, you'll have an option for Video Recorder (tab on top). If you play any source on the HDD, then all you have to do is press the Rec option on the Archos. If you already have a file on the HDD, then try just moving it over into the Archos once you connect the Docking station to your computer via USB or just use the USB cable connected to the computer with the HDD. I use the USB preference as Windows Media Device. (found under menu/settings/system). Is is basically a HDD itself. Remember the Archos will only play certain videos without the purchase of any extra plugins.
Good Luck
Apr 14, 2008 | Archos 605 WiFi Digital Media Player
77 people viewed this question
 Grubhead
Grubhead
