Question about ASUS A8V-VM Motherboard
Cant Dictect sata hard disk
When I am installing windows xp- spII I cant get my Sata Hard Disk. How can I solve this promlem?
  • 781 Answers
You do not have SATA drivers on the disk
Download "driverspack" one word from here
http://driverpacks.net/DriverPacks/
the Driverpack massstorage one
Download "Nlite" install it
You may have to get someone to do it for you
copy your Windows CD to hard drive and insert driverpack into the driver section of it
then burn to another CD
"Nlite is easy to use just read instructions
Posted on Nov 24, 2008
I cant download op cd
If the new hard disk is a SATA hard disl then the problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Feb 18, 2012 | Computers & Internet
I want to disable sata mode on my sony vaio vgn-fs742/w, please help because i cant reinstall xp on the system and the lan and wireless in not working when i install windows 7 on it.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jun 29, 2011 | Sony VAIO VGN-FS742/W Notebook
My hp compaq nx 6310 has windows 7 and it cant find a hdd during xp installation
The reason why the Windows XP cannot find the SATA hard disk in the installation process is because XP does not have a SATA driver on the installation CD.
To install Windows XP on a SATA hard drive, please click on this link and follow my instructions :-
Feb 06, 2011 | HP Compaq nx6310 Notebook
Can not installing windows xp & cant detecting the sata hard drive how can i installed the sata drivers
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive, this will make XP think it is a IDE/PATA hard disk.Then install XP normally. After Windows XP is installed then install all the device drivers (including the SATAdriver), then shut down and boot up and got into the BIOS and enable the SATAdrive.
Dec 15, 2010 | ASUS P5RD1-VM Motherboard
I cant install xp for the sata hard disks
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP.
The FIX.
Go into the BIOS and disable the SATA drive, this will make XP think it is a IDE/PATA hard disk. Then install XP normally, and all the device drivers (including the SATA driver).
Apr 02, 2010 | ASUS P4S800D-X Motherboard
No internal hard disk found
Hi there.
Use the Vista CD to create the new partition, but first you have to delete the old partition first, (the 220GB partition not the 10GB one because that will be the recovery partition).
Get a calculator and work out your new partition, for example 50GB is 50x1024MB so that will be 51200MB.
When you have deleted the 220GB partition select NEW and input your newly worked out partition and carry on from there, to activate the other partition just format it.
Please post back with the results and for anymore help if needed.
Good luck and thanks for using FixYa!!
May 24, 2009 | Dell Inspiron 1525 Notebook
I have a wd sata hard disk and i cant setup windows xp on it, it the monitor says ..... " windows can not find any hard disk instal into your motherboard " i need to solve this problem please thank you
Windows XP didn't have support for sata drives. You will need to load the driver by pressing F6 when you start the Windows setup. You will see the message
Press F6 to load 3rd party drivers at the bottom of the screen when Windows is installing.
Apr 06, 2009 | MSI Computers & Internet
XP on HP Pavilion dv2000
i think you have a sata hard disk drive.so go to cmos setup and in the cmos setup and please disable the sata drive there
Jan 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
Windows Setup cant find hard disk ?????????????
Does the BIOS on your system see the drive and show it's model information? Is this the only drive on the system? If the answer is yes for both, then you can download free utilities from the web to wipe the drive clean. This will result in the loss of all existing data on your drive. You can search for "Wipe Disk" and will get several hits for free software. Once you have cleaned the drive, try instlling XP. If the BIOS does not see your drive, the XP can't see it. You may want to try other SATA ports on your motherboard, or try changing the IDE configuration in the BIOS. Let me know if this works.
Aug 29, 2007 | MSI K7N2 Delta-ILSR (MS-6570-030)...
ASUS A8V-VM Motherboard Logo
176 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
