I have had the sims 2 on pc for about two years at least, and i have never had any problems with it until recently. When i click the fridge for example the menu shows for 2 seconds and if i move my mouse to click an option it closes before i get a chance. how do i fix this?
  • 162 Answers
Scan your computer for Spywares and viruses there is a software free of cost you can download and install it . after that perform full scan.
Download free version from
This will resolve your issue.
Posted on Nov 24, 2008
Fridge not cooling as well as it did until recently.? It normally operates ok at 2-3 but now cooling poorly at 4 and upwards
Youve got more food in it so it needs more energy.
the doors are not sealing shut make sure its sealing properly .
Is it old ,, when you say normally do you mean 2-3 weeks ago or 2-3 years ago .
have you checked the manual for troubleshooting
have you contacted the manufacturers customer support
Nov 15, 2016 | Refrigerators
We have a Magic Chef MCWC52B
The light may be old, and need repairing, I would try contacting somebody local rather than buying a new one.
Nov 30, 2007 | Magic Chef MCWC30MCG Compact Wine Cooler
My fridge freezer is less than 2 years old and the freezer is not working could it still be under warrenty?
If your fridge is self defrosting then you probably have a stuck defrost timer motor/switch. I can usually be found on the bottom of the front ourside of the fridge. You can try to advance it with a screw driver until you hear a click and once you do hear that click the fan and the compressor should turn on. Ifthey do then you will need to have the defrost timer replaced. After two years I doubt it is in warrenty. The only things that should be in warrenty is the compressor and all of the related tubing in the hermedically sealed unit..
I have had this problem many times and since I am a retierd HVAC engineer I was able to fix these defrost timers, mainly the actual motors that had dried bushings. You would first have to take the timer apart and get into those bushings and use a small amount of a good light oil like 3 in 1 oli. That usually does the trick.
Hope this helped you. If it did then would you please let me know, I would be courious to know.
Good luck,
Jun 26, 2014 | Beko Fridge/freezer Thermostat Genuine...
I have an LG fridge w/bottom freezer model LRBN22511TT approx 9 yrs old. Actually haven't had any troubles with the unit until recently. It seems the compressor isn't coming on, but there is an occasional...
The starting relay may be the culprit and is very inexpensive to replace. It is probably worth fixing.
After it is fixed, make sure you get the condenser fins cleaned.
Dec 12, 2010 | LG Refrigerators
9 years should not be a death warrant. I believe your defrost relay (bottom front area under grill) has gotten stuck on. It's a small black box about 3x4inches with a timer motor built in it. When it is ON the heater in the freezer coils turns on and defrosts. When it turns back OFF the compressor is allowed to come back on.
Dec 05, 2010 | Refrigerators
My refrigerator does not cool any more. I put it OFF for one hour now and there is no frosting. I checked all the grids and there is no ice etc in the fridge. It is a Inglis Side by Side 2 door fridge...
Check the cycle timer this is usually 90% of call outs for this issue. They are usually locate inside fridge on the top by light ( some times on the lower outside back of unit). Put a flat head screw driver in and slowly turn until you hear a click and compressor should kick in. If this works you will have to replace timer or it will freeze up in several days but will keep you cooling until then. Good luck!!
Apr 11, 2017 | Jenn-Air JCD2292KTB Side by Side...
No SIM card installed
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Jul 18, 2009 | Apple iPhone Smartphone
Neff K9724 Fridge Freezer with water in the fridge drawers
sounds like a thermastat problem or maybe your drain away hole is blocked
Apr 25, 2009 | Neff K9724X4GB
Automatic Hard Reset
a loose battery can bring such problems. make sure battery is properly tight fit in its cabin. polish the contact points if they are not clean.
good luck
Jan 31, 2008 | O2 Xda IIs Pocket PC
Leaking Fridge
you may have a faulty defrost timer, best consult a local dom apps store.
May 17, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
