Question about Amana ARS266ZBS Side by Side Refrigerator
Ice maker water wont shut off continues to run even when tray is full
Water to ice maker still continues to sned water to the icemaker even when tray is full and bucket is full of ice. Crates a large icecicle in the freezer.
  • 6 more comments
  • Anonymous Mar 27, 2008
    We have a 1992 Kenmore Refrigerator and the lever for the ice maker wont shut off the ice maker it keeps making ice like the switch isn't even their. What should i check or who do i call?
  • gigi1362 Mar 10, 2009
    Maytag single door swing - noticed an icicle and broke it off. The ice maker has been acting weird lately; thin ice, not enough ice, etc. Just happened to check the ice container and noticed the whole thing was full of water! Yikes! There is not any water flowing now but I worry about overflow later... Thank you in advance for your advice
  • Anonymous Mar 19, 2014
    Replaced ice make but now water continue to flow
    wont dumb the ice from the tray
    our wayer in our ice maker would not shut off and it caused a flood
  • Anonymous Mar 22, 2014
    power light goes off like the ice bucket is full
  • Anonymous Mar 23, 2014
    The ice maker continues to moan and click and the ice harvest has ceased
  • Anonymous Mar 29, 2014
    The ice maker is on, the bin has been cleared and cleaned, the ice tray is full and frozen but it will not drop the ice.
  • 237 Answers
The ice maker water fill solenoid may be leaking by and needs to be replaced. If you disconnect the water line from the solenoid and you see it continues to flow water then that valve is not seating properly. Another slight possiblility is the ice maker motor module gear is stuck in the fill position. See the attached link for a diagram. If the geared wheel just happens to get stopped in the "fill" position it will fill with full force water. If there is only a trickle of water then the soleinoid valve is the more likely source of the problem. http://www.partselect.com/Schematics/Maytag/AA56-20.gif http://www.partselect.com/Schematics/Maytag/AA56-16.gif
Posted on Dec 31, 2006
Whirlpool Gold icemaker won't make ice
Try this and add tap water to the empty ice maker. Turn it on if off and if after the water freezes the ice maker cycles dumping the ice into ice bucket and if the ice maker does not refill with water on its own you will need to replace the=> 2188746 Water Inlet Valve
If the ice maker does nothing then replace the=>
2198597 Ice Maker Assembly
Thanks John Tripp Appliance 911
Feb 16, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Ice maker leaking into ice storage tray
start with hose replcement buy parts at sears water hose to main ice maker might have crack in it or the stopper is bad get in ther look close with brite light
Oct 14, 2008 | Refrigerators
U line ice maker, the water doesn't shut off after filling the tray.
Change the water inlet valve if it is off and water continues to bypass the valve when off...Sea Breeze
U-Line Refrigerator Parts
Water Inlet Valve 2552A
Mar 25, 2013 | U-Line Icemaker
My Ic13b icemaker but when ice tray is full it still adds water to icemaker causing it to overflow and freeze on bottom of freezer
either your ice maker is calling for too much water or the water valve isn't shutting off when the ice maker tells it too. The best thing to do is to change both the ice maker and the valve because if one is defective more than likely thee other will fail shortly
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 05, 2012 | Amana Refrigerators
Ice maker is leaking water at the rear of the ice maker, somewhere around the water inlet. Water is dripping slowly and building up an ice ***** BEHIND (outside) the ice cube storage bin AND inside the...
Hello,The reason all the ice freezes together and you see icecicles forming from the icemaker,is going to caused by the water inlet valve on the back of the refrig.is not fully closing but instead it's seeping water through it and dripping into the ice storage bucket. To stop that from happening the water inlet valve would need to be replaced.
On refrigerators that have a built in water filter,alot of times their will be 2 water valves and the one that is bad causing water to seep through it will be the one called the SECONDARY valve.
GENE
Sep 30, 2011 | Maytag MSD2454G Side by Side Refrigerator
The icemaker of our Samsung side by side refigerator gets full and clogged up frequently and although we can hear the machine churning inside, ice is not dispensed. We have put in a new water filter after...
Either the icemaker support is broken, DA61-01801A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray catches the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, part number DA63-02284B
Good luck,
Vlad
First Choice Appliance
Aug 17, 2010 | Samsung RS2630SH Side by Side Refrigerator
Ice maker not producing ice. Tried everything in the Troubleshooting section of Users Manual. Replaced water filter. The front water dispenser is working.
the most likely thing would be a bad water valve.try to reset the ice maker and watch to see if the tray fills up the fill tube could also be blocked with frozen water.the last thing is simply a bad ice maker.
Sep 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water still runs into ice bin after trays are full on our uline ice maker
This happens when the motor is running slow or the water switch is sticking. To take care of both things you need to replace the faceplate on the icemaker.
Sep 14, 2009 | U-Line Icemaker
Maytag ice maker will not release cubes
Sounds like it has a " seeping " water valve . Only thing to do is replace the water inlet valve . There is a certain amount of water to go into icemaker at fill . A seeping valve will let water continually drip into icemaker , making large cubes which icemaker cannot dump . A larger amount of seeping , will overfill the icemaker , and drip into the freezer and floor .
Aug 12, 2009 | Maytag Refrigerators
Amana ARS266ZBS Side by Side Refrigerator Logo
842 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
