Question about Indesit W 123 Front Load Washer
Fault f05 Hi have a indesit washing machine that comes up with f 05 ? and can not open door .....can you help ? pezzer
  • 8350 Nov 30, 2008
    i have w125x and it f05 problem
  • Indesit Master
  • 3,463 Answers
F05 means pressure switch jammed on full, firstly check that pump is working and that there is no blockage anywhere,
if it still does not work, then you are going to have to call an engineer.
Hope this helps.
Please leave feedback.
Posted on Dec 02, 2008
How to fix f-05 error
Error F05 on some Hotpoint washing machines means the pressure switch has "jammed" on, so the machine thinks it's full of water and refuses to spin. It may indeed be full of water - but not necessarily.
This error code is used on some Indesit washing machines too
Before a washing machine spins the laundry it needs a signal that the water has pumped away successfully so it knows that it's safe to spin. This error indicates that for various possible reasons it's not getting that signal.
This can be caused by a pump fault or blockage in the filter, but if this is the case then clearly when the fault occurs it should be stuck full of water or at least still have a fair amount inside.
Dec 17, 2014 | Washing Machines
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
Fault code f-05
Error code F05 denotes the pressure switch is jammed on full.
Remove the large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Indesit W 123 Front Load Washer
Fault code F05 on an indesit washing machine WIXE 167.it not emptying the water
Locate and remove large black fastened to bottom of drum.
Hop[e this helps you.
Dec 28, 2009 | Washing Machines
My indesit W1E167 1600 washing machine is flashing F-05, is there anyway I can unlock the door? It seems to go through the wash cycle but then perhaps gets stuck on the spin?
Error code F05 indicates pressure switch jammed on full.
Remove large black hose on bottom of drum.
Remove hose onto pump, check for obstruction here and in the pump.
Please rate my sol;ution.
Thanks.
Nov 15, 2009 | Select Brands Washing Machines
My indesit 1300 stops mid cycle and flashes f-05 help
pump blocked take plastic trim off bottom and unsrew filter is main cause or poss pressure switch jammed on full
Jun 07, 2009 | Indesit W 123 Front Load Washer
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Indesit we125. F-05 comes on screen. What does this mean?
Hi.
F05 mwans pressure switch jammed on full, check that pump is working o/k, if it is, and still showing fault, then you will have to call an engineer
Hope this helps.
Nov 22, 2008 | Washing Machines
Indesit we14
Hi l have a indesir WIE147 that keeps on flashing F 01 repair man came changed module and next day same thing happened again HELP PLEASE
Nov 13, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
1,423 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
