Question about Nintendo Wii Console
My wii remote has stopped working, no lights flash either
The remote does not work, i have treid sync it but it does not react it looks dead does not respond at all
    President:
  • 4,402 Answers
Try new battery also unplug wii from wall and try it again.
Posted on Nov 25, 2008
How do you connect a rock candy remote to Wii
Make sure you have fresh batteries in it. the little red button under the battery cover is the sync button. Push it and you should see the 4 blue lights flash on the remote. Push the sync button on the Wii (red button under the front flap) and wait a few seconds. The remote light should stop flashing and one of the lights should light, indicating which remote it is (1-4) Repeat as necessary or change the order of button pushing if it doesn't work the second time.
Mar 14, 2015 | ROCK Video Game Consoles & Games
I am change my wii remote batteries.but after change batteries my wii remote not work. please tell me.how i solve this. Thanks.
You have to sync the remote to the console. You'll have to hit the sync button on the back of the remote in the battery compartment, and the sync button under the flap near the disc slot on the front of the console, and hold them until the lights on the remote stop flashing.
Mar 16, 2011 | Nintendo Wii Console
I just got the wii fitness but my wii remote does not want to conect the lights flash and then just stops and the remote don't work what can i do
have you tried syncing the wii remotes ?
Note: Make sure you have placed batteries in the Wii Remote.
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
Dec 26, 2010 | Nintendo Wii Console
On my wii remote at the bottom of the remote belong 1&2 them lights all flashing and it will not pick up we change the batties still not working can you help me..
Nov 29, 2010 | Nintendo Wii Console
When I turn on WII it says ''press A to continue''ut nothing happens. I have changed the batteries in the remotes but they do not respond. I have checked the sensor is plugged in.
If you have multiple wii remotes, make sure the remote you are using is synced to your system. In case you are not sure how to do this:
1. Open the battery cover on the remote and press the red "SYNC" button. The lights on the remote should begin flashing.
2. Open the SD slot on the Wii system and press the "SYNC" button.
3. Once the lights on the remote stop flashing, the process is complete and you should be able to use your remote.
Remember, you have to go through this process with each new remote in order for it to work.
Feb 09, 2010 | Video Game Consoles & Games
On one of the wii controllers all i get is 4 blue lights flashing then nothing
The Wii-mote probably just needs to be synchronized to your Wii. Open the battery compartment on the back of your remote and open the front SD card slot on your Wii. Push the red SYNC button on the Wii and then the little red button on your Wii-moteand it should sync to your console.
Nov 10, 2009 | Nintendo Wii Remote Controller
Wii Remote will not stay sync with console
Have you tried the following? If this doesn't work then pleae provide details on details such as the batterys you are using, number of remotes, etc.
The Wii maunual does not give clear instructions how to reset and sync your Wii remotes. I have found that from time to time my remotes will not sync, especially after they have changed 'order' a couple of times. It appears there is a bug in the code that keeps track of remote codes, and it has a limited buffer for the storage of remote ID's / order. Here are quick step by step instructions how to reset the remote list on the Wii console and re-sync your Wii remotes.
  1. Un-plug the power cord from the back of the console for 5 minutes (60 seconds should do, but leave it off longer to ensure all the power drains).
  2. Plug the Wii back in, and turn on the power button.
  3. Open the panel on the front of the Wii unit. You will see a Red button.
  4. Open the back panel of the Wii remote where the batteries are installed. Beneath the batteries is a small button.
  5. Press and release the small button. The Blue lights on the front of the remote begin to flash.
  6. Press the Red button on the front of the Wii unit.
  7. The Blue lights on the remote should stop flashing after a few seconds. Then one Blue light will remain representing player 1.
  8. Repeat for remote 2, 3 and 4.
Dec 28, 2008 | Nintendo Wii Console
Wii Remote Control Stopped Working
This happened to my son. I did some reading and found out you have to resynchronize the remote. This is from the manual
1) Press the Power button on the Wii console to turn it on.
2)Remove th battery cover on the back of the remote and press the SYNC. button inside the cover. The Player LEDs will blink.
3)Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment
4)When the Player LED blinking stops,connection is complete. The LED that is illuminated indicates the player number.
This procedure must be followed for each additional Wii remote added to your system.
This worked for me, hope it helps you.
Jul 04, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
137 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
