Question about Canon Powershot SD450 / IXUS 55 Digital Camera
Replaced cracked lcd screen
I replaced the lcd screen, put camera back together, now it will not power up.
Is there some interlock for reassembly, reset, or fuse?
I used freshly charged batteries to test.
  • 10 more comments
  • phil_hurst Nov 25, 2008
    I don't have an a/c adapter.
    Have taken apart multiple times to re-check connections/procedure.
    There appear to be two ribbon cables involved.
    1 for the LCD, 1 for the backlight.
    I only replaced the LCD w/connected ribbon.
    I reseated cable with no change in lack of power.
    Power was working prior to LCD replacement.
    My previous LCD screen cracked. I aready replaced it, thats when the power issue arose.
    disassembled and reassembled, no change in condition.
    ribbon does not appear damaged, connection appears proper.
    tried connecting old LCD, no change
    As previously stated, I already replaced the LCD.
    I used the Thydzik link/web page for guidance.
    Tried removing battery, pressing power button, replacing battery, pressing button- no change
    link was not helpful
    I follwed directions, the LCD is placed properly, the ribbon is connected properly, no items appear to be loose, etc.
  • phil_hurst Nov 26, 2008
    Battery door closing properly
  • 849 Answers
Last option is to consult a authorized service center.
Posted on Nov 26, 2008
    Novelist:
    Scholar:
  • 85 Answers
There is a tiny little switch inside the camera that is pressed when you close the battery door.
if the battery door is not lined up perfectly so that it presses this little switch when it is closed then the camera will not turn on.
check battery door to see if it is closing all the way solid.
Posted on Nov 25, 2008
  • Darren Kessinger
    Darren Kessinger Nov 26, 2008
    ok then maybe check little switch that battery door presses when closed its on the side of the door that is in the middle of the bottom .
    i only stress this point because i have experienced the exact problem your having with the exact same model camera that i have right here in front of me and i took it apart three times before realizing what was wrong and i didn’t figure it out until i pressed on the bottom of the camera on the battery door while pressing power at the same time and it turned on and it turned out that the very small plastic edge had broke off so that the door looked closed properly but actually wasn’t if you press on the door it should not move at all if you can press on it and it moves even a micro amount then it is not pressing the switch ..
    that switch connects all power to the camera maybe board it is mounted to inside is not perfectly straight or something or disconnected or something
    ok i just check my camera and the switch is right next to the sdcard slot its a tiny thin black thing like a little lever i am going to get out my other canon camera and take a close up pic of it and post it here in a few minutes so you can compare to yours
    see pic here:: http://systemonenetworking.com/fixya/can...
    Sergeant:
  • 291 Answers
While replacing the screen some part of the device must hve loosened up causing this problem.re assemple it again after dissassembling it to solve the problem.
    Genius:
  • 1,011 Answers
Sir,
Check this link for your problem.....
Thanks
Good Luck
  • 1 more comment
  • Asfiya Ahamed
    Asfiya Ahamed Nov 25, 2008
    Check this LINK
  • Asfiya Ahamed
    different screen won't work. The best case is that you would find a
    screen that fits and uses the same connector. In that case if you use a
    lower resolution screen you will only see a portion of what you are
    supposed to see. If you used a higher resolution screen you would only
    use a portion of the screen.
  • Asfiya Ahamed
    many cameras is often the cause of the LCD cracking. The case does not
    indicate which way the camera should be placed. There is a snap-on
    button on one side. If the user chooses wrong and places the camera LCD
    in the case facing the button, that button with the right amount of
    pressure can crack the screen.
    Better to contact manufacturer. They will help.
    Thanks
    good luck
  • Canon Master
  • 1,879 Answers
Re-assembling the camera to re-seat the connections.
  • monk3ybidzness
    monk3ybidzness Nov 25, 2008
    if you reconnect the cracked lcd, would it power on ?
  • 162 Answers
Try an ac adapter first. refer to the service manual for connections.
  • Canon Master
  • 19,396 Answers
No, but there are broken contacts and shorts, you need to disassembly again and to check all connectors.
  • 1 more comment
  • Ginko
    Ginko Nov 25, 2008
    I think there are two main ribbon cables connected to the board , and there are sveral ather connectors, if any of the cables had moved or had broken, the camera does not start up.
    I see if I find disassembly instructions.
  • Ginko
    Ginko Nov 25, 2008
    To start, if the LCD ribbon cable had shorted, the camera won't start, at home it is a bit of a problem to test this.
    The other ribbon cable has also the lines that power the board, if the ribbon cable is damaged, the camera gets no power.
    That is the best scenarion, because if something had shorted on the assembly, it can have blown soe on board component, and in that case it is unlikely a home repair.
  • Ginko
    Ginko Nov 25, 2008
    Check also the connections in the red spot at the left there you find the cable for the on button , check connections in there.
    See the disassembly here Powershot SD450
    Sometimes soldering joint may break during disassembly, and that is difficult to find out.
I had my camera in my back pocket. I sat on it and cracked the LCD.
No way anyone can say what is defect. Not even sure the defect was induced while you cracked the screen and became worse during the "repair" or you did make an little error while putting things together. Even in my professional career as a repair engineer, Trying to find an error after a college could not get it fixed complete, were the most difficult jobs.
My best hint for this? start saving for a new camera. Will save you a lot of greef and a lot of time.
Apr 06, 2015 | Sony Cyber-Shot DSC-WX9 Digital Camera
Blank screen after putting in a new LCD
did the ribbon cable stay connected during reassembly? these are difficult to work on.
Mar 12, 2014 | Samsung Exhibit 2 Smartphone
How to replace lcd on env touch vx11000
This one is VERY tricky. I wouldn't let anyone touch it unless they had a lot of experience taking apart phones and putting them back together. Basically, the LCD screen (all LCD screens) is stuck on your phone by a really strong adhesive sticker. I DO NOT recommend trying to pry it off because it will only break or crack a screen. What you have to do is unscrew those tiny little screws that connect the surrounding body of the phone to the LCD screen, then pop off the body of it. Then, CAREFULLY unstick the screen, replace it, and put it back together.
Jun 18, 2010 | LG enV Touch VX11000 Cell Phone
Cracked screen sony dsc-w50
* * * * * * * * *C A U T I O N * * * * * * * * *  BE AWARE OF THE HIGH VOLTAGE ON THE FLASH CAPACITOR. SHORT THE TWO LEADS ON THE BOTTOM OF CAPACITOR TOGETHER WITH AN INSULATED FLAT BLADE SCREWDRIVER. THE BIG SNAP THAT OCCURS TELLS YOU THE CAPACITOR HAS BEEN DISCHARGED
Go to eBay or somewhere similar where you can buy a LCD screen for your Sony-W50 without having to swing by the bank and take out a loan.
Next, assuming you now have the LCD display, open the camera by removing the screws on side and bottom. Open camera carefully. You will obviously see the LCD display. It will be connected to the PCB with a ribbon cable. That ribbon cable will go to a header. Be very careful when releasing the ribbon cable header because it is very easy to damage the flimsy connector.
New LCD should plug in directly like to old one. Do your self a favor and insure the unit power up and the display is not garbled. You can get a garbled display if the ribbon cable into the header is not seated properly. Once you have observed a clean display, reassemble the camera and have fun. * * * * * * * * *C A U T I O N * * * * * * * * *  BE AWARE OF THE HIGH VOLTAGE ON THE FLASH CAPACITOR. SHORT THE TWO LEADS ON THE BOTTOM OF CAPACITOR TOGETHER WITH AN INSULATED FLAT BLADE SCREWDRIVER. THE BIG SNAP THAT OCCURS TELLS YOU THE CAPACITOR HAS BEEN DISCHARGED
Jul 26, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
Black Spot in center of view finder
it could be cracked lcd screen and would need repair
Oct 21, 2008 | Olympus FE-210 Digital Camera
Kodak EasyShare C743 Digital camra has cracked LCD
Hey iheartcheer,
If you intend on paying someone to replace your lcd screen the repair will most likely cost more than the value of the camera, but you could have an estimate done at an authorized service center.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 18, 2008 | Kodak EasyShare C513 Digital Camera
Lines across the LCD screen
Two things can cause lines across the LCD either horizontal or vertically. The first (and most likely) is a small crack in the display wafer. LCD stands for Liquid Cristal Display. They are very fragile and can be easily damaged if dropped. I broke one in my pants pocket.
The second would be if a pin on the ribbon cable (to the LDC wafer) was not making good contact. If you disassemble the camera it is possible to clean the contacts using contact cleaner (or alcohol). Only attempt this is you are willing to replace the camera if you don’t put it back together properly.
Mar 11, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Canon IXUS 50 Digital Camera LCD not working
I beleive (this is only from my memory) their are 2 different LCD for this camera, sounds like you got the wrong one from canon, need to be sure its the same part number as your old one
Sep 03, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Cracked screen
these units are so fragile that you are undertaking very skilled surgery. it maybe that somehting became unplugged or pressured on the putting back together. Now that you have done it once, I would suggest taking it apart again and just putting it back together, it maybe that it will work the second time! there is no reset button that I know of. let me know if this helps.
Jun 20, 2007 | Canon PowerShot SD1000 Digital Camera
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
