Question about Hitachi 50FX18B/19K 50" Rear Projection Television
50 inch rear projection Hitachi looks like your watching in 3d
I have a 12 year old Hitachi model #50FX18B V6G002327 that intermitently has the problem of the screen duplicating and adding lines across the screen. It looks like if we had 3d movie without the glasses. It used to be that it would do this for 10 minutes or so and then go away. Now it does it from the second you turn the tv on and then comes and goes as it sees fit.
Please help, this is driving me crazy.
  • seansearle Nov 28, 2008
    Thank you. I'm in hot pursuit to do what you suggested. Thank you for the direction.
  • seansearle Dec 09, 2008
    Worked like a charm. Thanks for the help, saved me lots of money!
  • 4,234 Answers
This is a convergence problem and igf you can solder, you can probably fix this yourself. If you feel comfortable working inside the set, and are aware of the dangers of the high voltage present there. try the following: Resolder the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Dan
Posted on Nov 24, 2008
I need to find a replacement bulb for a Hitachi 50FX18B..vintage 1996...???
The bulb is a picture tube and this set has three, for you it means since the picture tubes for this model have not been available for several years you may need to retire it.
Nov 24, 2012 | Hitachi Televison & Video
I have a hitachi 50FX18B and the convergence lines are not aligne
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 24, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
I have a hitachi 50FX18B and the convergence lines are not lining up and the picture looks like you are looking through 3D glasses. How do I fix this??
This is a problem with the convergence circuit. If you can solder, you can fix this yourself. Please note as well that there are potentially dangerous high voltages present even when the set is unplugged. That being said... Open up the back and locate the convergence ICs (large black ICs attached to a heatsink and marked STKxxx). Try resoldering the pins on these ICs first. If that fails to resolve the problem, replace the ICs. There may be other related components that need to be replaced as well, but start with the ICs.
Keep us posted.
Dan
Jan 22, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
Hitachi 50fx18b 50" projection no power
Does it chirp? If so you need convergence chips replaced.
Read the link below.
  • Screen looks 3D
  • TV Makes Chirping Sound
Jan 07, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
1996 Hitachi 50FX18B 50"
  • Screen looks 3D
Jul 24, 2008 | Hitachi 50FX18B/19K 50" Rear Projection...
Hitachi 50fx18b
Press "shift" on remote to write to Rom. "Rom write" is displayed. Press shift again. Wait about 25 seconds, then press "mute" to return to convergence mode.
Mar 02, 2008 | Hitachi 50FX18B/19K 50" Rear Projection...
Hitachi 50FX18B
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 13, 2007 | Hitachi 50FX18B/19K 50" Rear Projection...
Televison & Video Logo
132 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
