Question about Canon PIXMA MP130 All-In-One InkJet Printer
Cannot scan to canon scanner 1730 laser class result NG #0801
We cannot scan from or to 5 different 1730 laser class all in ones.
2 Suggested Answers
canontech
  • 1219 Answers
SOURCE: Canon ImageRunner 2016 - scanner Not working properly
Ir 2016, can be onlly pull scanner, so that means that you must have installed scan gear, selected in scan gear, and over microsoft word or similar insert scan ( INSERT PICTURE FROM SCANNER OR CAMERA ), but the machine must be in scan mode, put original on platen or dadf, and then "pull it"from PC.
Hope that helped
pls.rate
Posted on May 14, 2010
I have a Cannon (copier / scanner )imagerunner 1730if I wanted to know how many pages can I scan at a time.
Google canon 1730if .this should give you different options . (.Manuel, reviews, etc.).or go to canon usa and key in the model.this should give you specs, reviews, price, etc.
Jan 13, 2015 | Canon ImageRunner 1730 Digital Copier
NOT SCANNING OR COPYING
These problems occurs when the scanner is unable to take a copy of the image that you are trying to scan.You can go to settings and run a scanner motor test on the scanner.Just check out the results of the scanner motor test.If the scanner motor test results are positive,then please clen the scanner bed with a cotton cloth and then perform a power drain on the printer.
Now in order to perform a power drain you need to keep the printr powered on n unplug the power cable from the back of the printer.And then press the power button down for 30-50 secs n then release it.Then plug in the power cable n turn on the printer. The scaner will respond. But if the scanner motor test results are negative, then the scanner needs to be fixed by a hardware technician
Dec 16, 2013 | Canon Imageclass Mf8080Cw Wireless...
Scanner not woking
If you can make copies but you cannot scan documents to folder or email then I would consult your resident IT person. If you are not able to make copies but the machine prints then you have a bad scan lamp. If you are not able to make copies or print and the scan lamp is as bright as can be then your laser unit is shot.
CANON IMAGE CLASS SUPPLIES
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Sep 12, 2012 | Canon imageCLASS D1120 Copier
Hope that helped
pls.rate
Sep 30, 2009 | Canon imageRUNNER 2016 All-In-One Laser...
Two sided scanning
Nope. It's not an auto duplexing feeder.
Mar 29, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Need list of Fax result codes for Canon MF5550
NG 070 = Issue: ERROR LCD: CLEAR ADF, DOCUMENT TOO LONG
Solution: Reduce the length of the document
Reduce the length of the document to within 14" (356 mm).
Sep 03, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Canon DR-2580C Scanner
You must have 'checked' the multipage option in the scanning software. Try scanning first page only and store as say temp1 and later all pages as temp2. If the file size is different you can deduce that the scanner has scanned all pages! To view multipage files, you need a proper software.
S. Mohan, Chennai
Nov 29, 2007 | Canon DR-2580C Path-Through Scanner
Canon PIXMA MP130 All-In-One InkJet Printer Logo
579 people viewed this question
old marine
old marine
