Question about Memorex MLT2022 20 in. EDTV-Ready LCD Television
19 inch portable TV Memorex
I've hooked up the TV to cable. Just a blue screen that says no signal. No sound or picture.
  • llove Mar 04, 2008
    My tv worked fine for a month. one day when turned it on to watch a movie it was just a blank blue screen that said "no signal" and it wont change from that. I unplugged everything, turned it off and on. nothing worked.
  • Anonymous Mar 15, 2014
    Grundig 19! TV blue screen reads no signal
Hi! I realize that you posed a couple years ago, but I am having the same problem with my relatively new Memorex MLT 3221 model. How did you solve it??? I have tried every 'layman' solution that I can think of! Please help!
Posted on May 19, 2010
    New Friend:
I just got a used Memorex MT2024 that's also doing the same thing. Sorry that's not a solution.
Posted on Mar 03, 2013
Memorex MLT1912: Signal only coming through on two channels
Did you try setting and finding the other missing channels manually?
Jan 03, 2008 | Televison & Video
My 19 inch Emerson tv screen has went blue an no picture isn't showing
Sounds like a bad connection to whatever you have it connected to (cable box, dvd player, etc). Check the connection and then replace cables.
Feb 13, 2015 | Emerson LD195EM8 19 in. LCD TV
I have a memorex. I am getting sound but no picture. When powered on, the memorex sign shows up but then no picture just sound. Also makes a slight screeching sound for approx 10 sec. when powered on.
I guess the blanket draped over the TV is intended to give it a "timeout". Anyway, you will likely conclude eventually that the internal power supply has failed.
Jan 02, 2014 | Memorex MLT1921 19 in. LCD TV
Broksonic 19 inch CCVG 1935 - no sound, no picture, just a blue screen
Blue screen means either no signal (if unit has rear connections hook a DVD etc to one and go to that input and see if it works) Or the blue may mean set is in shutdown----5 months old and it should still have a warranty?
Apr 23, 2012 | Broksonic CCVG1935 19 in. LCD TV
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
My t.v. turns on for 20 seconds then it just cuts the picture off but i can still hear the sound
The way to test whether or not the television needs to be repaired is to do some things to it after it has cut off the picture. Making sure you can still hear the sound but no longer see the picture turn the volume up and down. If you can hear the volume increasing and decreasing, but you cannot see the volume indicator itself on the screen then you'll know that possibly the inverter(s) is/are loose or that the inverter board needs to be replaced. If you can see the volume indicator moving back and forth across your television screen then you might have a problem with your signal source i.e. your set top box (cable box/satellite tv box), your connecting cables or the connections themselves.
Apr 21, 2011 | Memorex MLT1921 19 in. LCD TV
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
I have no picture but do have sound whats wrong?
check your VGA cable is it working...because the sound is operated from the desktop PC itself and not from the screen, if sound is OK,meaning that system unit is OK but screen problem, check VGA cable. (cable from screen to PC)
Oct 05, 2009 | Memorex MLT1912 19 in. LCD TV
Picture goes off and on every couple of seconds
If you are hooked up to a HD source if the signal is too high will cause this to happen. Normally this will happen due to signal interuptions such as signal being low will cause freeze, too high will cause it to go out and cause the TV to show default blue.
Good luck to you.
Sep 20, 2009 | Memorex MLT1921 19 in. LCD TV
Memorex MLT2022 20 in. EDTV-Ready LCD Television Logo
236 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
