Question about Frigidaire FRS26R4A Side by Side Refrigerator
Refrigerator not turning on
I have a kenmore top freeze,it seems to go through the cooling cycle fine but once it turns off i have to give it a tap inside the refrig. where the tempature control is for it to turn back on.i thought maybe loose wires in temp control box but that wasnt it ..any suggestions it just ran out of its 60 day warrenty
it does turn on by itself at times but 9/10 im having to kick start it,but i cant stand in front of it 24/7 :(
    President:
  • Frigidaire Master
  • 2,651 Answers
Yea that s a short withinthe cold control assy itself replacing it is the only option, a simple enough repair, 2 wires a few screws parts probably about $50
Posted on Nov 25, 2008
Freezer gets cold and freezes and then thaws back out.
Sounds like a thermostat problem. Try turning it on to Max. If that does not help get in touch with the maker's website
Jan 29, 2014 | GE GTH22SHS Stainless Steel Top Freezer...
Fridge not cooling... Freezer is fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Sep 12, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The freezer seems fine but the other side is not very cool.
I had the same problem w/mine, Found out it was the timer. There is a timer on most fridge's that turn on a defrost lamp inside your fridge. That is why all fridgs are frostless now. They still freeze up, but a lamp will defrost them automaticly. When the coils freeze up, they wont cool the fridge side & but will still cool the freezer side. generally the timer is where the controls are, behind the cover.
Mar 31, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
I have a problem with my refrigerator not cooling consistently. It seems like at least once a day it will start warming up but the compressor doesn't come on. When I turn the temp up control nothing...
I believe this is normal behaviour in all auto defrost (which means virtually all modern) fridges. In fact, this short heating period is usually programmed to happen 2 to 3 times a day. You might rightly ask why the refrigerator compartment needs to undergo "defrost" cycles when the compartment is, if the refrigerator is operating correctly, above freezing? The reason is although the compartment is above freezing, its cooling coils are well below freezing temperature, and it's these coils that need the frequent defrosting, before they build up so much frost on them that they "ice up" and no longer allow the fan blown air that cools the refrigerator compartment to pass through them.
Nov 12, 2017 | Kenmore Refrigerators
I HAVE A KENMORE MODEL # 253.63732300 TOP FREEZER REFRIGERATOR. IT HAS BEEN IN STORAGE FOR 2 YEARS. I GOT IT OUT AND PLUGGED IT UP TO USE IT BUT NOW THE FREEZER & REFRIGERATOR WILL NOT GET COLD. WHAT...
Was the refrig on its side at any time during movement and if so , was it left standing for 24 hrs before turning on ?
Check the fans to see if frozen (rust ) from the humidity when unplugged . 1 in the freezer and 1 in the rear , cooling the compressor .
Try tapping on the thermostat , and see if refrig starts . Not a slight tap (except at first) but not a heavy tap either .
Excellent organization of your question , with the complete model number . Most do not give the first 3 numbers , therfore , unable to help them .
Oct 21, 2009 | Kenmore 61042 Top Freezer Refrigerator
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Kenmore Refrigerator Freezing Up - Won't Defrost
i have a side by side kenmore frig freezer on th frig side the pop is freezing up and the water that comes out the door whtat could be wrong
Oct 12, 2008 | Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
55 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
