Question about IBM Infoprint 1352 Laser Printer
IBM 1352 prints blank pages
Started with the horizontal (1"wide) line still printing the text, then went on prining blank pages only
SOURCE: Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Posted on Apr 30, 2008
SOURCE: IBM 4234 dot matrix
Sounds like the configured paper sized does not match the actual paper page height. So that when it does Top Of Form paper movement the paper stops slightly too low. Doing several form feeds should confirm this. If this is it then reconfigure the paper size to match the paper. Also measure to paper to see if it matches what you want it to be.
Posted on Jun 13, 2008
  • 300 Answers
SOURCE: Info Print 1352 one half faded other half normal print.
You require a replacement transfer roller, if you remove the toner cartridge and look in the printer, you will see a roller which sits underneath the toner cartridge, this is what you need to replace
Posted on Apr 20, 2009
asish_shrm
  • 121 Answers
SOURCE: Canon s830d now only prints half a horizontal line of text
Remove the print head and do a through cleaning with damp cloth on the print head...this should resolve ur problem...if it doesnt ull need to change the print head
Keep me posted
Posted on Jun 15, 2009
  • 181 Answers
SOURCE: My Canon MP830 is having
clean cartridge and cartridge contacts with pencil eraser
Posted on Aug 12, 2011
Transfer Belt Leaving Color Streaks on Pages
Try replacing color toner of the same color that are the lines.If the void was in the same place all of the time then I would say use a Q tip dipped in 90 proof alcohol and clean laser.
Apr 21, 2014 | Brother BU300CL Transfer Belt, 50,000...
I am getting horizontal lines on the printed page. the quality of the print if fine for the exception of the three horizontal lines. The first line is about one inch from the top of the page, the second...
Regularly spaced horizontal lines suggest that there is a defect on the drum in the printer. I would suggest changing the drum to see if that will fix the problem.
Oct 08, 2010 | IBM Network Printer 17 Laser
Pages sticking to fuserwhen leading ege has wide
Replace the fuser, its overheating and that would cause the pages to stick the way they have been when trying to print pages of lots of black solid ink.
Apr 19, 2010 | IBM Infoprint 1572 Laser Printer
Horizontal lines (red) on first 1 - 2 pages of initial print-out
Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
Aug 17, 2009 | Epson Stylus Photo 1270 InkJet Printer
Jan 13, 2009 | IBM Infoprint 1352 Laser Printer
Will not Print
Try a hardware check of the printer first. To check the hardware of the printer, do the following:
  1. Switch off the printer.
  2. Load one sheet of paper into the paper feeder.
  3. Press the Power button and the Paper Feed button at the same time and hold them both down for three seconds. Then release the Power button only.
  4. When the printer begins to print, release the Paper Feed button. A page will be printed. The page should contain some text at the top and a series of horizontal color lines (cyan, magenta and yellow) below the text, with a thick black line below the colored lines. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not switch off the printer, it will continue to print.
Sep 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
All of my text is not printing.
Considering that the problem lessens further down the page, you most likely have a printhead that may be leaking (oozing) ink.
Once the surplus is wiped off on your paper, the ink flow is OK and the leak too slow to continue making the unwanted lines..
Try printing blank documents, you will probably see the lines with or without text printing.
I'm not certain how the printhead can be removed for inspection on that machine but it may need replacement.
Apr 28, 2008 | Lexmark X125 All-In-One InkJet Printer
I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Oct 27, 2007 | Canon PIXMA MP130 All-In-One InkJet...
IBM Infoprint 1352 Laser missing an inch of test on the left hand side
could be, but first take out the cartridge then look inside the unit there is a black roller, kind of spongy or hard rubber, is the black part towards the right? grab it and give it a tug and see if you can SLIDE it to the left if so then it needs to be replaced, that is your problem.
It could also be the fuser, are the copies on the left coming out smudged or with a grainy shadow? then it's the fuser.
Oct 11, 2007 | IBM Infoprint 1352 Laser Printer
Aug 14, 2007 | Dell 3100cn Laser Printer
IBM Infoprint 1352 Laser Printer Logo
56 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
