Canon IR 5070 waste toner?
I read through the forums, found a few posts about waste toner but none match the beast I am stuck with!
We have a Canon IR 5070 and I cannot for the life of me find the waste toner. Nobody in the building knows how to empty it. There is nothing on the Canon website. Can somebody help me? How do I change/empty the waste toner?
Thanks!
  • 2 more comments
  • Joe Tetrault Nov 24, 2008
    There is no lower right cover with one screw. The only cover with a single screw is on the back, it hides what looks like an air filter. On the right side of the machine there are 2 large covers, neither requiring a screw to be loosened and a couple of panels with multiple screws.
    I found it, right side of machine, vertical panel with 2 screws and the power switch. Undo the 2 screws and behold the bottle! Turned out to be lass than 1/4 full, gave it a shake and put it back. All set now.
  • Anonymous Mar 24, 2014
    where do i find waste toner container in canon ir 3225
  • ali saeed
    ali saeed Feb 10, 2015
    THANKS ........... VERY GOOD
  • 318 Answers
Hi
If you losen the lower right cover of your machine you will find the bottel there.
This lower right cover you will find on the right side of the machine,it is the lower small cover.There is only one skrew to losen,remove the cover and then the bottle.Empty the bottle and put it back.
Hope this will help.
Posted on Nov 24, 2008
How to solve canon ir 3300 error code e0000190000
Neele, Error code E000019-0000 is a waste toner full , to get rid of this error, remove the waste toner bottle located left rear side of the machine,dispose of waste toner and clean the neck of the bottle because waste toner could obstruct the toner sensor beam. Switch off then on, OK to use.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread Canon IR 2200 Error E000019 0000
Canon ERROR 19 Waste Toner Tank
Jun 13, 2014 | Canon (6981A002AA) for imagerunner 2200,...
Canon IR 3225 error 0000-191-0000
Error code E000019-0000 is a waste toner full error, in order to get rid of this error you need to remove the waste toner bottle located in the left side of the machine
May 31, 2014 | Canon imageRUNNER 3225 Black and White...
Canon image runner ir 5070 error E00020
E0020. problem with developing unit. sometimes or often toner doesn't full of motor developer, it is may be the toner become froze or no toner.
Dec 26, 2012 | Canon Image Runner 1630 Copier Copier
CANON 5070 IMAGEWRITER POSTING "WASTE
To remove the recovery unit, open the upper right door & remove the developing unit. Be careful to unplug the toner sensor at the front frame. The plug will be damaged otherwise. From the front remove all the corona units. Slide out the fuser drawer. Remove the retainer screw & lock in the drum shaft. Slide out the imaging unit.
The recovery can now be removed.
Jan 20, 2011 | Canon imageRUNNER 5000 Copier
Display on screen when I copying document for a few sheet of paper : system error E019 What is the meaning.
the code error e019 means that the waste toner is full,you must change the drum is 2 in 1 waste toner and the drum are the same ,you can take out the toner of the drum .
Nov 23, 2010 | Canon iR 2016i Black and White Copier
Where is the waste toner receptacle located on the canon IR 3300i
Lower rear right portion has a small vertical panel held by one screw. The waste bottle is behind this panel.
Aug 13, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Waste toner collection IR 5570
remove the small lower( rear)right side cover 2screw then you will see the waste bottle youcan pull it out and throw away the waste toner
Jul 15, 2009 | Canon imageRUNNER 5570 Copier
Canon 5070 - Error code E000013-0000
This is the error code for a clogged waste toner auger. If you heard a clicking sound coming from the rear of the copier before the error you have clogged waste toner . This may take a long time to clear. May have been caused by not emptying the waste toner bottle when it indicated to do so and the waste toner backed up on itself. You may have to remove most of the items at the rear of the copier to either replace the auger pipe assy or just the slip gears that drive the auger. I've never looked forward to doing this on any of the copiers that have an auger system. If you're not a tech a tech should be called and may take several hours depending on how serious it is to clear. Good Luck.
Oct 10, 2008 | Canon imageRUNNER 5000 Copier
1,542 people viewed this question
jasbo
jasbo
