SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
SOURCE: My Konica Minolta MC2300DL will not print. It is
You can change the 2300's menu setting to ignore empty toner cartridges and keep printing. There are 2 steps:
Step 1:
Press Menu/Select, then "right arrow" until you see ENGINE. Press Menu/Select again and then "right arrow" until you see TONER EMPTY. Press Menu/Select and you'll see STOP. Press "right arrow" once to change to CONTINUE. Press Menu/Select.
Step 2:
Press "right arrow" until you see AUTO CONTINUE. If set to ON, press the "Cancel" button and you're ready to print. If set to OFF, press Menu/Select, then right arrow to change to ON, then Menu/Select to enter. It will say "ON IS SELECTED." Then press the "Cancel" button and you're ready to print.
SOURCE: how can u resolve all lights blinking on minolta
Unplug from PC, unplug from wall, leave unplugged for say 5 mins, and then plug back into the Wall, then, reboot PC, then plug into PC. Now should be OK. If NOT please use the manual below to troubleshoot whats wrong.
http://kmbs.konicaminolta.us/content/products/models/magicolor1600W.html
SOURCE: Hi, I just bought a
HI
Please remove your cartridge and check you remove the all security strip in cartridge.
