JVC UX-HB4 reading 'no disc'
I have had this system for a couple of years, but it has sat in an unopened box until now.  All original packaging remained intact, and it was stored in a dry place at normal room temperature. I now find that it will not play any CDs - display just reads 'no disc' and the machine does not even make any sounds to suggest that it is trying to read the disc. It has not worked once since I opened it.I wonder if you have any suggestions?
Vivekt1000
  • 35 Answers
SOURCE: CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Posted on Aug 14, 2007
robotek
  • 1512 Answers
SOURCE: Cannot get music CD's to read.
The lens have a bad habit of falling out of the optic assemblies. They are held in with only a 2 dabs of glue. You can VERY CAREFULLY glue it back in. It is a plastic lens and affected badly by the wrong type of glue. Use a craft/modelling glue. DO NOT USE SUPER GLUE It will cloud the lens and render it useless.
  1. Remove the lid and remove the 4 screws that retain the laser traverse assemly(it has a brown flexifilm attached to it). dont UNPLUG ANYTHING
  2. Gently turn the entire optics assembly over by carefully maneuvering it(there is an earth strap to unscrew that may make it easier).
  3. Wit the assembly facing upwards, refit the lens back into the laser assembly, ensuring that it is sitting entirely flat
  4. Then use a tiny dab of glue( I use a Tarzan's Grip, a craft glue ) to EITHER SIDE of the lens making sure that it is dabbed on both the lens and the mount that it fits into
  5. Let the glue go off(couple of hours)
  6. Clean the lens with a cotton tip moist with windex(glass cleaner), and then again another dry one to be sure there is no smear left.
  7. Remount the traverse assembly and test
Check that the rubber suspension mounts have not perished also If they have collapsed(they should sit within about 1mm of the retainer screws when refitted), they will need to be replaced also. You will need to get them from a Pioneer service center. They are about $1.00 each.
APPLY SPARINGLY. Glue everywhere or on the face of the lens can easily destroy the coating.
This method works 4 out of 5 times without having to do the grating adjustments on the optics. And save you $100 for new optics and time to set them up. Good luck, and dont forget to rate me "FixYa" If you need more advice on these players... i have fixed hundreds of them. They are well worth repair and hard to replace with anything similar. .
Posted on Feb 06, 2008
  • 3 Answers
SOURCE: Discs stuck inside CD Player. Screen says ''Reading.''
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
Posted on Mar 16, 2009
localwonder
  • 6784 Answers
SOURCE: Denon DCM 390 not longer reads discs--HELP!
Hi there, this lens may be dirty or it may have a thin layer of heat film that is causing it to not read in a consistent manner. i would try to clean the lens with a good CD lens cleaner. if the cleansing doesn't restore the lens to its original reading state, this will confirm lens assembly failure and you will need to replace this assembly.
Posted on May 18, 2009
localwonder
  • 6784 Answers
SOURCE: Will not read the disc
The optical lens assembly is damaged at this point. the lens has burned out and the tracking/load motor seems to be faulty as well. replace the optical lens asap.
Posted on Jun 03, 2009
Tuning a JVC UX-d237B micro system
Hello here is a tip.maybe you have already tried this but on the back you have the speakers and a pair of red and black switches, you have to put the wires into the holes on the TOP (not the sides) of the little box on the back...then once you have put the wires in flick the flaps UP :)
JVC UX LP5 Micro Desktop Stereo System JR com
Jan 10, 2018 | JVC Audio Players & Recorders
Locked cd drawer
The JVC UX-GN6 disc ejection lock can be toggled on and off by pressing the Stop and Eject buttons on the main unit (not the remote) when the micro-component system is in standby mode. These buttons are on the bottom row on either side of the Down arrow/Input Selection button. See page 4 of the manual, which is available on the product page: http://support.jvc.com/consumer/product.jsp?modelId=MODL028509 . The direct link to the manual is currently http://resources.jvc.com/Resources/00/01/15/99.PDF .
I hope this helps.
Dec 31, 2013 | JVC UX-GN6 120 Watts Micro Component...
The jvc UX-GP5 has no charge power to the ipod
Put a golf ball behind your Ipod, this will push the connections down. I had the same problem after 4 years of use and the golf ball has been working great for the past 5 years.
Dec 24, 2011 | JVC UX-GP5 Micro Stereo Audio System Shelf...
MY CD PLAYER IS LOCKED, THE TRAY DOES NOT OPEN. IT IS A JVC MODEL UX-GN6
Hi .
It's so easy! I hope I can help to You.
For unlock the JVC Cd Disc You only have to put Your Machine in OFF mode and press at the same time the STOP and the EJECT bottoms.
For lock the CD player again You have to do the same process but with the machine in ON Position.
All the best from Spain
Jol Macana
Jun 03, 2011 | JVC UX-GN6 120 Watts Micro Component...
JVS UX S59, every time original disc inserted readsawhile and comes up saying no disc. please help, also adio not working. Everything was working fine, stereo has not been moved or dropped. Thanks Andy
the main problem with this is the laser .
the category 1 lasers are very sensitive .
the solution is to make sure your cd's are clean , not scratched and the final thing to do is clean the lenses of your JVC S59 make sure to keep this unit in a dust free enviroment .
Sep 26, 2009 | JVC UX-S57 CD Shelf System
JVC UX-N1 No playback
Audio amplifier IC damageed need to be replaced good luck
Feb 14, 2009 | JVC UX-N1 Shelf System
NO COLOR-JVC UX-P550
chnge the colour system of your player to auto mode .read the instruction manual.
nuwan
Nov 21, 2008 | JVC UX-P550 System
94 people viewed this question
 Grubhead
Grubhead
