Question about JVC DX-T9 System
Dx-T9 JVC tRAY ERROR KEEPS APPEARING AND TRAY WONT OPEN OR PLAY
TRAY ERROR KEEPS APPEARING AND THE TRAY WONT OPEN AND I AM UNABLE TO PLAY ANY DISCS PLEASE HELP IM LOST WITHOUT THE USE OF THIS STEREO!! THANKS
silly girl
  • 513 Answers
SOURCE: tray error
I saw on another JVC systems manual that its an error message that shows when the tray isn't fully open due to an obstruction. If you can locate a manual eject button(usualy you'll need to insert some tip into it) it will help you eject the tray and look for any obstructions, anything looking out of the ordinary there. at least that way you'll be able to take your cds out... You can also try disconnecting the system from all power sources for a few days(including an internal battery), maybe the reset will jog it back to working order. If you're out of warranty and know your way around those things, try taking it apart, cleaning as much as you can, and look for anything out of the ordinary, like broken gears or pins, bent parts, a cog, etc. Good luck
Posted on Feb 13, 2006
techman
  • 3130 Answers
SOURCE: System unresponsive when modes are switched
Sounds like there may be a glitch in the microprocesor. Make sure when you unplug it that you leave it along for a few days and is there any type of clock or standby batterys in it take them out as well. If that dosent correct the problem your gonna need a service manual to trace the switch pulse to see if the units Switch matrix lines are low or lost because of a faulty micro or a bad componet like a small caps they install on the matrix to keep noise off them. Hard one to call with out seeing unit and analizing unit Good Luck
Posted on Apr 12, 2006
snakehead
  • 1074 Answers
SOURCE: disc compartment won't open
Plug the dvd out then your plug it in back to reset it self.if that do not work take it to a tech to look at it the dvd ould be having a mechanical problem.the gears could be worn out or broken.good luck.
Posted on Apr 01, 2007
  • 22 Answers
SOURCE: blu-ray dvd disc error on jvc th-g41.
if your blu-ray is updateable then get update also try other disks
Posted on Apr 25, 2010
lock123
  • 6831 Answers
SOURCE: my jvc wont play disc's
Hello
OK, if you already tried to clean the laser lens, you might be out of luck, because it is the laser lens which cases this problem.
You can try running another laser lens cleaner disc, if this doesn't work, the lens itself is burnt out.
Sorry..
Kind regards
Andrea
Posted on Aug 31, 2010
C.d.s get stuck and now tray wont close
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
May 04, 2012 | Onkyo DX-C390 6-Disc CD Changer
My jvc 5 disc player wont play cd nor dvd.says tray errr. wont open to eject dics or play
It is possible that the loading belt needs to be replaced, or the timing gears are out of sink, either way it must be taken apart to find the problem, sometimes I find the gears ware out causing the unit to lock up. When you hit the eject button do you hear a motor running? that should be the sound of the loading mechanism trying to eject the tray.
Dec 23, 2010 | JVC FS-GD7 Shelf System
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
My dx-t9 dont have power
If you know how to measure, then check Transformer output (Low voltage). If not good, replace the transformer
Jan 01, 2010 | JVC DX-T9 System
I am getting the locked display
Hi Blackhawk,
This sounds like you've accidentally set the "tray lock" feature.
You can set this to stop unwanted tray ejections:
I hope this solves your problem..
Warm Regards
Mike
Nov 28, 2009 | JVC TH-M303 System
Cd tray won't open; won't play cd or turn off
No solution - plastic thread driving opening/closing had snapped after 16 years!
May 17, 2009 | JVC XL-M509TN 7-Disc CD Changer
Jvc dvd player not playing
Even you don"t have a remote you can play it manually and DVD player play it automatically.Just try this open the tray put the DVD disc on the tray and close it then turn it off for 30 seconds then turns it on then it play automatically if not then there's something wrong to the player.
Hope it may help you:
Regards:
VOTIT
Mar 23, 2009 | Audio Players & Recorders
DISC TRAY WONT CLOSE... PLEASE HELP !!!!1
the drive switch is broken try to buy a new one and then it should work coz my dad works in the computer part
Dec 07, 2008 | Microsoft Xbox 360 Console
My dvd/cd try does not open when i press the eject button say "locked"
That means your trays are on Child Lock (this is a safety feature to prevent any accidental opening or closing of disc trays by small children when listening to your favorite tracks.)
To solve this, simply switch off your radio to Standby and hold the power button...whilst holding the power button, press open on the tray that is locked....the system will display UNLOCKED on the display of your hi-fi.
That should be it. To lock the tray....repeat the same process on the particular tray u want locked.
May 21, 2007 | JVC DX-T9 System
JVC DX-T9 System Logo
640 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
