SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
SOURCE: prob with PTO on craftsman mower 917.273372
There is a idler pivot plate on the mower that must be cleaned and lubricated regularly, from the left side of the mower deck if you look in the middle of the mower deck while someone engages the mower(with the engine off) you will see the pulley try and move,there is a 3/8 bolt that comes up through a bushing that this pivots on, soak that area with wd-40 and see if that improves the movement. Be sure not to get any wd-40 on the belt or pulleys. Always try and keep that area clean and lubed.
SOURCE: When I put the mower in gear, or engage the
Sounds like the seat safety switch is shorted or worn out. You can test it with a short length (about 6") of wire. Strip about a half inch from each end of the wire, unplug the connector under the seat and plug your "jumper" wire in to each side of the connector (NOT the seat switch) If it now works, replace the seat switch
Testimonial: "Thanks. The problem was the seat safety switch was loose and not fully engaged. When I plugged it in correctly, everything worked!!! Thanks again."
