Question about Fuji FinePix S5500 Digital Camera
MENU/OK & 4-Directional Button jammed
I can not view all my pictures on my LCD monitor or use the menu as the button appears to be jammed. Have had a quote from Fujifilm of £99.90 for a standard repair! Is this something we could fix easily ourselves or does it need to go in for repair? Many Thanks.
Try taking it into Jessops you may get a better price there
Posted on Dec 31, 2006
How do I unlock the security lock on the stand from the desk.
Hi
go on setting and reset all setting. it will come on normal mood.
May 25, 2016 | Sony SDM M81 18.1" LCD Monitor
43 inch plasma samsung tv with abnormal picture size .i want to adjust but i dont have serivce menu codes please help.
Using The Remote Control Your remote control will have a button on it to quickly adjust the picture size.
  1. Press the P.SIZE button.
  1. The current picture size will be displayed on the screen.
  1. Press the P.SIZE button repeatedly until the desired picture size is selected.
  2. Important: Some picture sizes are only available with certain resolutions or certain inputs.
Using The On-Screen Menu
  1. Press the MENU button. [The Main Menu appears]
  1. The Picture portion of the Main Menu will be selected by default, if it is not selected use the directional arrows to select the Picture portion.
  1. Use the directional arrows to select Screen Adjustments, and then press ENTER.
  1. Picture Size will be selected by default if not use the directional arrows to select Picture Size, and then press ENTER.
  2. Note: The current picture size selection will be displayed to the right.
  1. Use the directional arrows to select the desired picture size, and then press ENTER.
Nov 12, 2013 | Cell Phones
How do I set the date
1. Close the lens barrier and press the LCD monitor ON/OFF button to turn on the LCD monitor.
2. Press the Menu button to display the Menu.
• See page 37 for how to use the Menu.
3. Press the top/bottom arrows on the Jog dial to select MODE SETUP, then press the right arrow.
4. Select the date order using the top/bottom arrows on the Jog dial. Press the right arrow on the Jog dial to adjust the first setting month/day/year.
5. Press the top/bottom arrows on the Jog dial to adjust the first setting, then press the right arrow on the Jog dial to adjust the second setting.
Repeat until the minute is adjusted.
• 00 will appear for the year 2000.
6. Press the OK button to save the setting. Press again to cancel the Menu.
• For accurate setting, press the OK button when the clock hits
00 seconds.
• If the Menu button is pressed before the OK button, the
setting and Menu mode will be canceled
Jan 31, 2012 | Olympus D-460 Zoom Digital Camera
LCD 170S7FB/00 shoeing message that ( MONITOR CONTROLS LOCKED) I'm traying to fix that problem by press the menu botton about 15 seconds, But also doesn't work thanks
Take a tooth-pick. Jam it between the OK button and the next button. so that the OK button stays permanently depressed. This makes the message go away. After a long time (in my case 30 hours) you will suddenly see the that the controls are unlocked. Magic.
Mar 02, 2011 | Philips 170S6FB/27 17" LCD Monitor
I did not open my game on my Phone V3 If i open then came a massage "No Installed MIDLet Suites" Please solve my problem
  • 1 Press the V3's "Menu/OK" button, located in the center of the directional keypad.
  • 2 Use the arrow keys on the directional keypad to navigate the menu down to the "Settings" option, then press the "Menu/OK" button.
  • 3 Select the "Initial Setup" option in the Settings menu and then select the "Master Reset" option in the Initial Setup menu.
  • 4 Enter "000000" into the field in the Master Reset menu; if you've changed your L9 security code, enter the new code instead. Press the "Menu/OK" button.
  • Dec 27, 2010 | Cell Phones
    I would convert an french my samsung e250
    Follow this steps,
    1. Press the "Menu" button, or select the "Menu" option, on your Samsung phone. Your phone menu will now appear.
    1. 2.Scroll through the menu using the directional pad and highlight the "Settings" option. Press the button in the center of the directional pad to continue.
      3. Scroll to the "Phone" option and press the middle button. Then scroll to the "Language" option and press the middle button. The phone will now show two fields: "Screen text" and "Input language."
      4. Scroll to the "Screen text" field and press the soft key under the word "Change." A list of the available languages will now appear in a drop-down box. On Samsung phones that use a SIM card, an available option is called "Automatic," which will default the phone to the language of the SIM card.
      5. Scroll to the language you want and press the "OK" button.
      6. Highlight the "Input language" field and press the "Change" soft key. Scroll to the language you want and press the "OK" button.
      7.Press the soft key under the word "Save" to save your changes and return to the phone settings menu.
    Nov 23, 2010 | Samsung SGHE250i Cell Phone
    Im trying to adjust my philips lcd but menu says "osd main control is locked" how can I unlock it?
    In order to resolve the OSD menu locked error:
    1. You must reset the on screen display in the menu.
    2. Hold down the Menu button for at least 60 seconds.
    3. A menu list will appear on your monitor screen.
    4. Using the adjust button, press the arrows to enter the menu.
    5. Scroll down to the Reset section.
    6. On the right side of your screen, you will see an alternating Yes/No choice.
    7. When the Yes message flashes, press the Ok button.
    8. The menu should be reset and the flashing OSD control message should disappear.
    Apr 12, 2010 | Philips 190B6CB/27 19" LCD
    Camera settings appear on viewfinder screen
    Ok I just posted that I had the same problem and I just figured it out by trial and error. What I did was
    press the playback button.
    press OK
    it will take you to the edit picture menu and the first choice is D-lighting. It should be highlighted Yellow. press Ok and then the screen will come up with 2 of your picture with different lighting. choose which ever one you want then press OK. The image will save and then the camera info should go away. I have NO idea why this worked but it did and I hope this works for you!!
    Dec 22, 2008 | Nikon D40x Digital Camera
    No picture & not able to access OSD to reset
    Sounds like your OSD is locked. Press and hold the "OK" button for 10 seconds or so and it should unlock.
    Oct 30, 2008 | Philips 170S4FG 17" LCD Monitor
    Fuji FinePix S5500 Digital Camera Logo
    32 people viewed this question
    Top Fuji Cameras Experts
    Steven Wander
    Steven Wander
    KJ Soni
    Level 1 Expert
    Parshiv Luthra
    Are you a Fuji Camera Expert? Answer questions, earn points and help others
