Question about Dishwashers
Dishwasher door leak
General Electric built in dishwasher has started leaking at bottom of door. How do I determine why and how do I fix?Unit is 6 years old an runs fine otherwise.
  • 1 more comment
  • steamboat27 Nov 24, 2008
    The bottom center section of the tub gasket that the bottom of the door sets on has gaps that leak water onto th floor'
  • Anonymous Jan 16, 2009
    I have the same problem and my seal is fine. It leaks in the bottom right corner.
  • gdeuel Mar 11, 2009
    GE Profile Diswasher. Bottom door seal is torn.. I have a replacement. I have taken out the 5 screws but cannot disloge the old seal. Seale is rubber (or rubber like) with plastic semi ridgid rail. How do I install?
    Sergeant:
    Champion:
  • 338 Answers
At the bottom of the door is going to be the door seal starting to go bad. replace the seal
Posted on Dec 01, 2008
Leaking at the bottom in the middle of the door
you need to determine if it's coming from inside the door or under the front of the dishwasher, if the door latch needs adjusting it can get water through the latch slot, the dispenser can work it's way loose and water can leak through it, or the seal on the bottom of the door can get dirt stuck on it which can cause water to leak out.
Otherwise it could be in the bottom of the dishwasher, it is a matter of closer investigation.
Mar 10, 2012 | GE 24 in. Profile PDW7800 Built-in...
Leaking at the bottom of the door and unsure where plastic door seal goes.
This dishwasher will leak if there is to much water in the unit.
I have the same dishwasher with a different problem.
Mine won't circulate the water. I have not use it for a while and some water will back feed from the sink and fill the dishwasher, so if I don't check for that problem once in a while I see it start to leak.
It never has done that when the unit was working....
Aug 28, 2011 | Jenn-Air 24 in. JDB1100AWS Built-in...
Brand new kenmore dishwasher leaking out the front
Check the door gasket for uniform seating. Align it. If this does not solve the problem, contact the service provider. He may change the gasket or do the corrective action.
May 25, 2010 | Kenmore 13743 Staimless Steel Built-in...
Eurotech Dishwasher is leaking - How to get to the guts to fix it
When a dishwasher leaks, it is usually the door seal or the water level gone wrong. Assuming the door was never leaned-on and the hinges bent, then you look to the seal or in some cases a splashshield fin that goes along the bottom between door and frame. If the unit is more than 7 or 8 years, the seal or shield plate could have lost its shape enough to allow water to get by.
The other problem, is the water level is too hi and this can be because the float switch is filled with soap scum and is heavier than normal, so the float thinks there needs to be more water than usual. Clean the float, you may need to remove a guard shroud to access the float. Goodluck, macgivor
Jan 02, 2010 | EuroTech EDW242C Stainless Steel Built-in...
Door leaks on a general electric potscrubber 980 dishwasher
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Sep 26, 2009 | General Electric GE Appliances 24 in....
Bosch 6802UC dishwasher is leaking water from bottom of door
Leaking Dishwasher
heatman101
Jan 22, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Diswawasher leaks
hi , it can be the door seal dirty or damage but it can be also the spray arm :
Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , open the door after few min check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
I hope you find this Very Helpful and best regards!
Jan 05, 2009 | General Electric CDW9380N Built-in...
Dishwashers Logo
227 people viewed this question
Top Dishwashers Experts
