Question about HP DESKJETS - OFFICEJET PRO L7680 AIO PR Printer
L7680 has no IP, Subnet Mask or Default Gateway.
I have tried in vain to add the IP, Subnet and Default gateway to this machine (this is our 3rd replacement) for a Wired Lan. Have tried the automatic and the manual settings. Even the manual settings won't stay when added. Thanks.
POCBM
  • 121 Answers
SOURCE: Where do I change the IP/Gateway/Subnet on HP LaserJet 4000
You can set these on the printer using the EIO menu.
Press menu until EIO menu appears.
press item
Config network NO should show. press value YES should show.
press select.
Press item until config tcp/ip NO shows, press value Yes press select.
This should get you into the tcp/ip menu.
use item, value and select keys to navigate to the setting you want to change.
hope this helps
Posted on Mar 24, 2009
  • 1525 Answers
SOURCE: ip address,subnet mask, gateway
168.192.1.1
shaun
Posted on Sep 19, 2009
veenu goel
  • 38 Answers
SOURCE: how to configure my tcp/ip TP-link access point
click on start
go to run
then type cmd
type ipconfig (in case of window)
Posted on Nov 06, 2009
nkrcs
  • 94 Answers
SOURCE: HI,
Normally most internal LAN addressing is carried out by a DHCP server which issues IP addresses to anything that is connected to the network.
IE your computer. most switches are set to obtain an IP address from them as a default. to find the IP address of youe switch you need to look at your DHCP server ( possibly your router/modem) and see what addresses have been issued. Once you have found the address it is a simple task to open your internet browser and type in the ip address of your switch. once there you should be able to configure your switch as per your requirements.
Posted on Jul 20, 2010
  • 34 Answers
SOURCE: HOW DO I PROGRAM THE IP ADDRESS, THE SUBNET MASK,
It is explaned in the user manual. you can download it at US.RISO.COM
Posted on Sep 09, 2010
I just configured my MFC 490cw for wireless printing. It works but now I have IP address conflicts across all computers XP & Windows 7) and X-box in the house. If I turn the printer off, the network...
When configuring an address for the printer, the IP configuration might look like (just an example):
IP Address - 192.168.1.2
Subnet Mask - 255.255.255.0
Default Gateway - 192.168.1.1
It's important to note that even though you are not using any IP addresses in the default range for DHCP, the Subnet Mask and Default Gateway addresses will be THE SAME.
If you have another device on your network that will be assign a fixed address, you would use for example:
IP Address - 192.168.1.3
For any other devices, just increment the IP address by one, 192.168.1.4, 192.168.1.5, etc and use the same Subnet Mask and Default Gateway.
(see the owners manual or site for steps on configuraing the printer TCP/IP information). This should take care of any conflicts.
Jan 29, 2011 | Brother MFC 490cw Color Inkjet...
The WGT624 v3 internet globe is blinking but the wireless light is not illuminated
Make sure the physical connection is good between the computer in question and the D-Link gateway. If you do not have a solid link light, try swapping cables. Make sure the ethernet adapter is installed and functioning properly.
If you are running any firewall software on the computer that cannot connect, disable it. Make sure the TCP/IP settings are set to obtain an IP address automatically. Try releasing and renewing the IP address for your ethernet adapter. It should pull a 192.168.0.x address with a subnet mask of 255.255.255.0 and a default gateway of 192.168.0.1. If it does not get an IP address in this range, specify the address to be 192.168.0.10, subnet mask 255.255.255.0, and add the default gateway and primary DNS 192.168.0.1. Try and go online.
If it still cannot get online, go to the Control Panel and open Internet Options. Restore the default settings on the Security and Advanced tabs. On the Configuration tab, make sure the Dial Up setting is set to never dial a connection. Click the LAN settings button. All you want selected here is automatically detect settings, uncheck the other two boxes. Try and go online.
Nov 13, 2010 | Computers & Internet
Linksys NH1005 V2.2 Ethernet 10/100 5 Port Hub Router. I cant get the other computers connected to the hub to connect to the internet. I've tried everything.
Hello!
I will just illustrate on how to configure or to set the correct IP addressing;
Assuming that we will manually put IP address on each computer:
PC1:
IP Address: 192.168.1.13
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1
Preffered DNS server: 192.168.1.1
***note that 192.168.1.1 is the IP Address that your ISP gives to you, so on the other computer (see below)
PC2:
IP Address: 192.168.1.18
Hope I was able to help.
Oct 09, 2010 | Linksys (NH1005) 5x10/100 Mbps Networking...
Hi. i cant connect to print server d-link dp301p+ IP to configure it?! who knows what IP by default it have? 192.168.0.10 doesnt work... Thanks, Mike
First find out the IP address , Subnet mask,and Gateway addresses of your ISP ( Internet Service Provider ). According to above addresses, you have to complete the network settings of your printer by mentioning the different IP address .
To find out the above mentioned addresses, first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses.
Suppose your IP address is 192.168.0.10 , the gateway may be 192.168.0.1 Or any number. And the subnet mask may be XYY.XYY.XYY.0.
According to your ISP addresses you have to complete the network settings of your printer. First press the additional functions -> system settings -> network settings -> TCP/IP settings -> fill up the addresses as follows.
IP address : 192.168.0.16 OR any number .
subnet mask : XYY.XYY.XYY.0.
Gateway : 192.168.0.1
Hurray ! the problem about your network connection with the printer to your computer will be automatically solved.
Sep 28, 2010 | Computers & Internet
Laptop will not connect to wireless internet says it doesn't have a valid IP configuration. Have unplugged loads of times can get other wireless connections in the area but not mine.
In your laptop, try to put an IP Address, subnet mask, default gateway and preferred DNS server. (please see below)
example:
IP address: 192.168.1.13
Default Gateway: 192.168.1.1
DNS Server: 192.168.1.1
note: 192.168.1.1, is where your modem or your internet is connected (or the IP Address). This is the one that is provided/configured by your Internet Service Provider.
Jun 07, 2010 | Buffalo Technology Buffalo LinkStation...
How do I convert my C6180 all in one printer from offline to online status using a HP Pavillion dv9000?
Take out the Network Confirguration page from the printer.
To get the page.
Press the setup button.
Go to Network Setup>>>View Network Settings>>Network Configuration page. Press OK to get it printed.
Note down the IP address of the printer.
Then Go to The Printers folder under Control Panel.
Make right click on the printer icon and select Properties or printer properties in case of windows 7.
Go to Ports tab.
Click on Add a Port. Select Create a new port and select Standard TCP/IP
Enter the IP address that you have noted down from the Cofiguration Page.
And complete the Add a port wizard.
Then restart the printer.
. If you are using a DSL router, then enter Manual IP to the Printer.
Make sure it is different from the IP of other devices on network.
You must have default gateway, subnet mask information about the network.
To get the details.
Open Command Prompt on your computer from All Programs>>Accessories.
Enter ipconfig and press enter.
Then note down the IP address, default gateway and subnet mask.
To enter the manual IP to the printer, Press setup button. Go to Network Setup. Select Advance Settings>>>>IP Settings>>>manual IP.
Enter Ip address of priner as 192.168.001.023.
The default gateway must be 192.168.1.1, make sure that first 3 set of numbers are same. like 192.168.1, last 3 should be different from the computer's one.
Enter the same default gateway and same subnet mask
And after adding the manual IP, use ADD a Port option. Restart the printer and then check the status.
To make sure, make a right click on the printer icon and select Use Printer Online.
Apr 29, 2010 | HP Photosmart C6180 All-In-One InkJet...
I cannot get my Wii to connect to my 2wire router. We have not been able to connect ever since we switched to ATT. Please help.
I had a similiar problem; check your PC settings and find out your IP address, subnet mask, default gateway and DNS settings and write them down. (from "run", type "cmd", then in the window type "ipconfig /all")
if your IP address is (for example) 192.168.1.1 mask 255.255.255.0 and gateway is 192.168.1.254, go to your Wii settings and change the internet settings to NO DHCP, give the Wii an address of 192.168.1.10 with the same subnet mask, default gateway and DNS server setting as your PC. Remember the FIRST 3 numbers of the IP address must be the same and the last one DIFFERENT.
Mar 03, 2010 | 2wire (2701HG-B) Wireless Router
I ve adsl device for wireless sometime it works n sometime i ve to plug in cable because wireless function not works
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 10, 2009 | Dell (430-3572) Wireless Adapter
Low lan connectivity or limited lan connectivity
Hello Sir,
all computers on the same physical subnet need to have ip addresses in common
meaning the first three numbers in aaa.bbb.ccc.ddd are the same and are different only in the ddd portion.
In addition, the subnet mask must be alike or ensure that some ip addresses are not excluded
Typical subnet mask is 255.255.255.0 or sometime 255.255.254.0
Usually, there's a gatway address; a target which is used to send packets out
of this machine and hopefully towards the other machine.
For all machines, use the Run->cmd and enteripconfig /allYou should have similar results on all machines, so look for major differences eg: gateway on one is 0.0.0.0 or not shown while other have non-zeros,
or ip address on one start 169.254 another starts with 192.168
The 169.254.y.z addresses are pecuilar
ms article comments on auto-config:
example : IP-address assigned via Auto-IP-Configuration :
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Autoconfiguration IP Address.. . . : 169.254.4.69
Subnet Mask . . . . . . . . . . . . . .: 255.255.0.0
Default Gateway . . . . . . . . . . . . :
Thanks
Cheers!!!!!!
Good luck
Feb 29, 2008 | Computers & Internet
Adding additional computer problem
Yes, the xp machine connects to the net. DHCP is not enabled. The ipconfig/all command brings up the correct static ip address, subnet mask, and default gateway. But it does also say under the ip configuration that ip routing is not enabled. I did have the 2000 machine connected when I first set up the router yesterday, but I booted up my laptop to try to set up a wireless connection, and then I had to reinstall the entire router set-up.
Jan 12, 2008 | Linksys Wireless-G WRT54G Router
HP DESKJETS - OFFICEJET PRO L7680 AIO PR Printer Logo
64 people viewed this question
Ben Johnson
