Question about Frigidaire GLTF2940ES Front Load Washer
Help My washer is new and it shakes alot. Does washers have a safety botton? where?
  • 3 Answers
In that model there is internal shiping brakets that need to be removed try removing them let me know what happens
Posted on Jan 19, 2007
Washer clothes
Your load is out of balance.
If you have a heavy item, spread it around the tub to balance the load.
It is normal for the tub to shake during the spin cycle. The washer has a safety feature, if it is too badly out of balance it will shut itself down and sound an alarm.
Jun 01, 2014 | Whirlpool Refrigerators
Tub on washer shaking alot
Are you overloading it? Or load uneven can cause this to happen.
Jun 01, 2014 | Whirlpool Gold White-on-White 21.9 cu. ft....
My lg washer shake s alot when it is spining and makes a loud noise please can you help
The washer needs to sit on a solid foundation for this to work. When the washer is spinning a load of clothes, push the corner of the washer till the noise or vibration quiets down. When it does quiet down, adjust the leg below to reduce the noise.
Good luck
May 26, 2011 | LG WM-2277HW Front Load Washer
The washer shakes violently then the off balance sensor trips when a load is in the washer.
I had this washer at one point in time. was not very happy with it, even though i sold it to alot of my customers. usually if the machine is shaking violently it means one of a couple things. first make sure your washer is properly leveled. if it is make sure you washing the same types of clothes in the load, no mixed loads of towels with shirts. if your problem is not that then you possibly have a bad clutch. which will cause the tumbling wheels to spin during your spin cycle as well, its a costly fix so i would consider a new front loading maytag/whirpool if that is your problem. remember this machine was designed by maytag, since then they were purchased by whirlpool and everything is on a whirlpool platform now. if you do purchase a new washer and have the matching dryer to your neptune TL, it would recommended to replace the dryer as well, considering the capacity of these machines are smaller then most of the new high efficiency machines on the market today.
Feb 19, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Washer shakes when spining. More on heavier loads.
shaking is generally due to inadequate floor structure under machine; i.e. plywood floor. in addition, if the washer is on a "pedistal" it will make matters worse; as the center of gravity is away from the floor. in rare cases, one of the drum "struts" can fall apart; and, cause excessive shaking. if you broke the locknut on one of the legs, unscrew the leg, and bring it to the hardware store for a replacement nut.
Feb 15, 2010 | LG WM2487H Front Load Washer
Washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer is shaking violently when it is time for the spin cycle
Hi you must make sure its level in all directions. ie front to back and side to side. Alos dont overload it. If its on a wooden floor it will vibrate. A concrete floor is the best
Feb 15, 2009 | Washing Machines
Check to see if all shipping blocks and bolts were removed. Refer to installation and setup instructions for your model.
I once moved into an apartment furnished with washer and dryer. The washer had worn holes in the vinyl flooring and a neighbor said the previous tenant made her son sit on the washer to hold it down. I investigated and found the shipping bolts were still in place. The tub, which is supposed to be able to swing, was rigidly held in place, so the entire machine danced around the room!
Jan 10, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Spin cycle problem
Which machine exactly do you have ?
Aug 31, 2007 | Kenmore Elite 45986 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
