Question about Sony Cyber-shot DSC-W50 Digital Camera
Flash problem So, I set the camera to 'Flash On'. I take a picture and the flash goes off for about a quick second. I look at the picture and it's nothing but a black background, sometimes white where I can only slightly see the object I took the picture of. What's wrong with my camera? This only happens sometimes, by the way. Sometimes I take a picture and everything's normal.
    Sniper:
  • 80 Answers
The CCD element has been a great problem in this camera along with a faulty iris in the lens. I would return the camera to the Sony facility in Laredo, TX and let them know the exact symptom you are having. I see many of these cameras being repaired as a "courtesy" because of the widespread problem. Good Luck to you! Joe Weibel Custom Electronics (customelectronics.org)
Posted on Feb 13, 2007
Shutter is lagging with sb-800 flash attached. flash goes off, 3 sec later shutter goes
Have you checked the flash mode?
I have no problems with the combination D300 SB-800.
I assume you don't have a picture if the flash goes off before the shutter open(?)
If you do check the menu e2 Flash shutter speed you can set it at a few seconds in spite of the fact that the flash sync (e1) is something reasonable like 1/250
The flash shutter speed is set to 1/60 in my camera...
Aug 21, 2009 | Nikon D300 Digital Camera
Screen goes blank after clicking a picture
This is the normal cycle time and it can increase if the batteries are a bit weak. This is one of the minor issues with this camera. You should only notice this when using a flash since it has to re-charge the flash circuit, without flash the picture should retuen in a second or less.
Sep 16, 2008 | Canon PowerShot A620 Digital Camera
When using flash, my sony cyber-shot dsc-t10 takes forever to take pictures!
Have you tried Hi-Speed memory cards, as writing speed of the card affects the response time of camera, I am using Sony MSX-M2GN 2GB and it's gives me quite good response.
Other thing you might try is format the memory card using camera, camera has card format functionality and it does also improve the performance of the camera.
Jul 16, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
When i take a picture with flash, the screen goes black and a red light flashes
after i take a picture on my nikon coolpix the screen goes black for about 30 seconds before you can take another picture.
Feb 10, 2008 | Nikon Coolpix S1 Digital Camera
Af and flash button flash continuously when camera switched on
How old is the camera? Take a new approach to Nikon. But costs are about right- it is no joke.
Aug 10, 2007 | Nikon Coolpix 5600 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M60 Digital Camera
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries. Please refer to the section pertaining to Battery Life.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
43 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
