Question about Sony Playstation 3 (PS3) Console
Playstation 3 display
Help, i was playing around and set the display to full think it was 1080 or something instead of the normal 500 something. . thought i would just change it back cause its not an hd tv. .but now its just blank and i can still hear the ps menu when i press the arrow buttons. . how can i change it back when i cant see anything?
  • 903 Answers
Press the power button on the front of the console until you hear 2 beeps, this should set the display back to normal
Posted on Nov 24, 2008
How to fix ps2 display settings
You can adjust screen display settings while playing PlayStation 2. Press the PS button on the Wireless Controller during gameplay and then select [Settings], adjust the following settings. Screen Mode Normal: Set to upscale and display at a size that matches the screen size. Full Screen: Set to upscale and display at full screen by changing proportions and stretching the image. This setting can be selected only when [Normal] or [Full Screen] is selected under Settings > [Game Settings] > [PS / PS2 Upscaler].
Mar 31, 2011 | Video Game Consoles & Games
New ps3,new 40in. samsung 3d led, new monster hdmis yet when i play god of war3 which is capable of 1080i it automatically gives me 720 not even 720p. so i unchecked 720p in setup and it gave me 1080 not...
To change this setting, you must exit the application and change your Video Output Settings from the display settings option in the Settings menu. Make sure the tv is not set on 720p/i and that it is set to 1080i. There has been issues with games that are 1080 downscaling the resolution. this can be confirmed by reading this article. if you provide me with the model of the tv. I can help assist you in ensuring its on 1080p. If you need further assistance please let me know after you try the following above. Thanks, Midwest-tek
Aug 28, 2010 | Sony Playstation 3 (PS3) Console
I m trying to change my ps3 from a screen to another. i connect it with hdmi but in the smaller screen doesn't play.the display settings are in hdmi mode in 1080i 1080p and lower.. The monitos that the...
This is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
all the best
Click Here
Jul 14, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 is set on the display 1080, i need to change it back to normal sd, but it doesnt display anything on my sd tv. how do i get it back to normal.
Please try the following steps to solve your PS3 problem :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 slim used to play blu-ray quality, now it has a snowy, speckled appearance and doesn't have that flow effect. my games and themes on my playstation look great and is in good HD format like...
double check display settings then the first open under there to see what it is set at maybe it defaulted back to 480 instead of hdmi 1080. Also try doing a lens cleaning from the disc that are brushless kmart sells them, and walmart but only online for wal mart this can drastically improve if its just a dirty lens doing it.
Apr 29, 2010 | Sony Playstation 2 Slim Black Console
Non-working ps3
hold the power button till it beeps twice , that will reset the settings , if it does come on then go to manual settings ,av settings, make sure ur tv is hdmi if u choose this option and choose either 720 dpi or 1080 if ur tv is full hd , if not do not choose these if ur using an av lead instead of a hdmi
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
My ps3 freezes everytime i play a game, but will play movies fine.
Hi mabee this may help try to down scale the game to take the load off the GPU dont run it at 1080 as they tend to overheat and the fan goes ballistic this is my theory of the cause of YLOD eg 1080 forced into a 640x480 tv something has to give and it wont be the TV
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
Playing on a regular TV.
Ensure you have returned the PS3 video output system setting to 480i vs the 720/1080 setting. Regular TV will give you a black screen at the higher resolutions.
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
PS3 Scart / HD
Turn it off with the "hard" switch in the back. Then turn it back on with the switch while pressing the power button on the front for 10 secs, this should reset your display settings.
Sep 07, 2008 | Sony Playstation 3 (PS3) Console
Ps3
Depending on your television, if it's a tube then your display settings should be at 480i and no higher. Sounds like you set it at 720 or 1080 and your TV can't handle the resolution. You need to go to the PS3 main screen (turn on without game in it) and select the "settings" ( might be called "system settings", 2nd or 3rd icon from the left), a sub menu will show up and look for the 'display settings' heading and change it back to 480i. That should do it. Reset the PS3 just to make sure the new settings take effect.
Jan 08, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
